Home > Td5 > Immobilised 90 that won't take EKA ? !! |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 |
Hi guys - problem with Betty as I can't start and remotes won't work to lock or unlock ...
Fitted sky tag at weekend and blew a fuse that I replaced but seems imobiliser has kicked in ... Strange thing is that the led on the speedo is solid red when the ignition key is at II - book says it should be flashing and alarm should sound after 5 seconds - I have tried to set the EKA code with the key turns/door opening but doesn't do anything ?? I've searched through the threads but cant find anything with all the same symptoms ... Any ideas gratefully received as I've got to try and get to work tomorrow !! Cheers Jon |
22nd Jun 2011 7:29pm |
Thanks Lorryman - that's worked - sadly can get to work tomorrow now
Jon |
22nd Jun 2011 9:15pm |
23rd Jun 2011 12:58pm |
