Home > Maintenance & Modifications > ARB Headlight upgrade loom |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
The Land Reiziger loom is great, it has a dual relay unlike the Boomslang which is single.
The two Relays are one for dipped, the other for main beam so you have two. The only reason the one you've suggested has 3 Relays that I can think of is a third fir axuillery feed for example a light bar. I actually have four Relays on mine, the Land Reiziger with two and two separate one for each light bar. On mine I swapped out the Relays for quality Duirte ones with diode, but I did have to swap ground and trigger pins to suit. If in doubt, get an auto electrical specialist to sort it out but it is well worth doing. My headlight switch has under 300 mA (0.3A.) going though it now, instead of the full headlight Load being 55w each headlight in standard factory fit. (Approx 8.5 - 9.4Amps total.) No Guts, No Glory. š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
20th Feb 2020 11:35pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Rather than pay a small fortune for a kit, it is far cheaper to go to an auto electric factor and buy the relevant parts. Then you can do it yourself for a fraction of the cost.
Did it about 15 years ago, using individual relays for dip and main on each headlamp thus giving me a total of 4 relays. Taking power straight from the alternator, via a fuse, to shorten the wiring runs. Also used 6mm cable https://www.vehiclewiringproducts.co.uk/c-...sq-84-0-30 to relays and 28 strand cable https://www.vehiclewiringproducts.co.uk/c-...sq-28-0-30 From relay to the load. It is not so much about "upgrading" the headlamp loom as taking the load off the headlamp switch, thus prolonging its lifespan. If you look at the wiring diagrams for older military vehicles, they had relays for things like the brake lights and horn as well. It is not a Defender, it is a One_Ten |
21st Feb 2020 3:36pm |
