Home > Maintenance & Modifications > Seat corner protectors DIY |
sconie Member Since: 10 Jan 2020 Location: Paisley Posts: 50 |
Hi all, thought I'd share my DIY seat corner fix. I found a few references to this on the forum so searched ebay. I found this black corner piece that does both sides 22cm each.
Nice and wide and totally cleans up the ugly rips. www.ebay.co.uk/itm/Fascia-Board-90-degree-...2749.l2649 £8.69 delivered and 5min to trim and fit. Click image to enlarge |
18th Feb 2020 12:28pm |
Yeah I think they all do as its a tight fit standard. It does have a rounded edge however so don't think it will damage the door cards.
18th Feb 2020 1:05pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
It won't damage the door cards, but it will leave it's mark long term, mine on both door cards
Click image to enlarge Click image to enlarge Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
18th Feb 2020 8:47pm |
Hmm.... I might use the leftover trim to make a wee square protector for both doors then? A bit of silicone should hold it and easy to remove without damage to the door card.
18th Feb 2020 8:55pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
I used these. Very cheap solution. They stick on fine with trim glue.
https://www.ebay.co.uk/itm/173133308054 |
18th Feb 2020 8:57pm |
Nice too but mines was too far down to get away with a small corner. Worth bookmarking though 👍
18th Feb 2020 9:08pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20563 |
+1 On what L110CDL said.
It doesn't however worry me one bit though. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Feb 2020 9:11pm |
