Home > Puma (Tdci) > Sudden and Catastrophic Engine Failure |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1780 |
Piston failed - early engines had faults with oil cooling jet under the crown IIRC
Timing chain stretched and jumped a tooth? Good luck |
15th Feb 2020 8:58pm |
KelvinB Member Since: 17 May 2018 Location: Crickhowell Posts: 24 |
Sounds as if it will be cheaper to get a new or recon short engine. Recon is only about £1800 and probably cheaper than spending loads of time in diagnosis and rebuild. Something similar happened to my 2008 2.4 at 105,000 miles.
15th Feb 2020 10:00pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
yep, sounds like this. that sucks, a recon engine, or a BMW conversion? https://www.facebook.com/257036848348064/posts/481209805930766/ -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
16th Feb 2020 8:21am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 621 |
I would question how good the “highly respected” Land Rover garage is if they can’t work out in ten minutes that a pre 2008 2.4 with those symptoms has more than likely suffered usual piston cooling jet failure, let alone two months.
16th Feb 2020 9:43am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
It would be highly unusual for a Puma with 120k km on the clock to suffer from the PCJ problem unless oil changes have been overlooked, and the manner of the failure as described is also not really consistent with this particular fault.
Personally I'd be more inclined to suspect a timing chain fault or possibly a catastrophic injector failure. It is certainly disappointing that a dealer is unable to diagnose what is clearly a very major fault (it should be much easier to diagnose than a minor one) and speaks volumes about how useless dealers are now they no longer employ proper mechanics. |
16th Feb 2020 1:19pm |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
I can't belive LR garage is not able to diagnose your engine. Did they remove the head and looked at it? Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
16th Feb 2020 1:30pm |
He's in France - they were going to but then they went for lunch!
16th Feb 2020 3:35pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8024 |
Timing guides worn as is tensioner and chain slipped/jumped? Cheers
16th Feb 2020 10:13pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 482 |
It's already been very difficult to identify the correct break pads for my 110 MY 2012 - far too complicated ... An entire engine must be way beyond their limits ... clearly ... I'd have the whole engine changed. That's an easy job for them. Not so intellectual P.S. A worn time chain rattles. He did not mention that. |
16th Feb 2020 11:03pm |
