Home > Tdi > Defender rear shock bushes - have I got the wrong ones?
KiwiNCFC
United Kingdom 1997 Defender 90 300 Tdi HT Arles Blue
Hey guys. Went to replace my lower shock absorber bushes today and I think I have ordered the wrong ones. I can't seem to find the correct bushes AND washers for my configuration. I have standard LR shocks but nearly all the usual sites bearmach/paddocks only have the domed style bush on the left in the photo below.
I went to fit them and I just do not have any thread left to get a nut on so they must be the wrong ones. Can anyone advise me to the correct bushes and washers? Ive seen that some chassis I've looked at online have cups that hold the bushes against the axle but I don't seem to have them. I have a 97 300tdi.
This was before I took the shock out (the bottom half fell out)
These are the new bushes (not 100% sure on orientation)
New on left , old on right
If anyone can help me find the proper bushes and all the washers as that seems quite hard to find too. I've seen a few on eBay but not entirely sure if they are correct as my current washers are so rusty and distorted it's hard to tell. Lastly, what thread size is on the shock? I have no nuts to try and will need to get some new nyloc nuts.
Many thanks 😎
Post #814325 9th Feb 2020 3:45pm
dorsetsmith
new bush you have are later axle with metal cups to site bushes into Chassis VINs from XA159807 (1999 MY)
552818 for Defender rear shock bushes upto 1998 MY see below
Also rear Lower Shock Absorber Washes two pre lower shock bush with early type Exclamation
Post #814329 9th Feb 2020 3:56pm
KiwiNCFC
Thanks so much. That helps a lot! That website is a good find!
Post #814341 9th Feb 2020 5:23pm
Oldowner
I have seen 96/97 defenders with the newer type axle cups, Discos had them from 1996, despite what parts catalogues say.
Post #814389 9th Feb 2020 8:08pm
dorsetsmith
All depends on axle build age fitted to your land rover at cross over
Post #814394 9th Feb 2020 8:17pm
keith
No.14 the nut. What’s correct size please?
Keith
Post #830758 12th May 2020 8:09pm
dorsetsmith
nut, M12, nyloc
Post #830760 12th May 2020 8:15pm
keith
DS. No it can’t be. Iv got an 18mm on.
It’s the bigboy nut on shock top.
Keith
Post #830762 12th May 2020 8:19pm
dorsetsmith
12mm threaded nut but you will use 19 mm spanner to remove the nut
Post #830767 12th May 2020 8:25pm
keith
Ah yes I see. Awesome thanks for info I had a feeling I had wrong size on although nice and tight fit.
Keith
Post #830768 12th May 2020 8:28pm
yostumpy
Another question.... the top mounting of the rear shock, has two washers with different size holes, to go either side of the upper mounting bush. These washers are flat one side and curved the other. Which side is supposed to face the rubber bush, flat or convex? And why? 'Volvo XC 70, taking the rough with the smooth’
Post #836476 11th Jun 2020 8:43am
hxk494
Convex facing bush for top mount.
Allows shock to move as suspension drops/rises. If flat side there's no movement and shock liable to snap off where it meets tube bush is fitted in. 1996 300Tdi Defender 110
Post #836497 11th Jun 2020 10:15am
yostumpy
ok cheers. Whistle 'Volvo XC 70, taking the rough with the smooth’
Post #836518 11th Jun 2020 11:30am
nitram17
The only true disappointing thing about this forum is the disappearance of vital photos ..this post is harmed by the removal of the images..I know why it happens but it doesn't deflect from my disappointment. This place is a wonderful resource for finding out stuff about your landy ..most of the time!
Post #979559 24th Jan 2023 3:03pm
geobloke
Yes... It is vary irritating when searching for answers... Rolling Eyes
Post #979561 24th Jan 2023 3:07pm
