![]() | Home > General & Technical (L663) > Ingenium engine issue |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
A few things I found this morning while doing my weekly check routine under the bonnet.........
A) I haven’t had a car with one of these in a long while - TBH I much prefer this to an electronic one as my experience has been frequent dash messages warning “Communication lost with oil level sender” ![]() And its a long one too and also not easy to relocate after reading as the tube seems a pretty small diameter, it is also easy not to push it fully home and seal it, it’s as if it has a “click to lock” on it. ![]() B) DPF on the 2.0ltr Diesel Took the car to the village garage who are LR Indies and they spent and hour on Saturday morning climbing all over it and commented that the DPF is one of the biggest that they’ve seen and its among the closest to the engine/turbo that they’ve seen so hopefully oil dilution is a thing of older Land Rover products. If that is the DPF I’ve circled in the picture then it’s well above the max wading depth too. ![]() ![]() ![]() C) The Auxy/ cam belts don’t look too difficult to access too on the front of the engine. - Please don’t leap on me - I’m not an engineer so the serpentine belt I saw might not be an Auxy/ Cam belt! D) Screen Washer bottle - it’s easy to access at the front of the engine bay and either I have used more water/ screen wash mixture than I thought or it’s a huge capacity washer bottle! It isn’t huge it’s only 6.25 litres, still about twice the capacity of the washerbottle on my old 90 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
