Home > Maintenance & Modifications > Internal Live Feed Question
The Fox
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I'm in the process of installing an internally-routed LIVE feed from the battery to the fusebox.
Is there any reason Why i can't/shouldn't connect up the new feed as well as leave the existing one in place. I can't think of a reason - but thought it best to check and see if someone has had an explosive experience which I should learn from!!
Post #813911 6th Feb 2020 3:03pm
I can think of two reasons:
1. It's quite crowded at the fuse box end and two connections may not fit.
2. If somebody does cut the cable under the seatbox, you're left with two live bare ends floating around, which is less than ideal. Particularly so if they're left and you don't know about it. Darren
Post #813922 6th Feb 2020 3:54pm
grafty99
I have run a second set of cables. Only small gauge, but rated enough to power all of my security. Its fused so if the cables underneath are chopped and I go to start it then it will blow the fuse and I can start to investigate.
Also if they do chop the cables underneath they'll get a bit of a shock when all the security still works Twisted Evil 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #813927 6th Feb 2020 4:45pm
90 Dreamer
Can you not just wire it so they stay live when hacked and give them a belt hopefully......... Laughing
Post #813953 6th Feb 2020 7:19pm
The only downside I can see for leaving the old is the significant fire risk of cut live ends dangling underneath. It'd be a shame to deter the thief only to have the vehicle incinerate itself.
Post #813962 6th Feb 2020 7:46pm
grafty99
Would the main fuse not blow with the enormous current draw? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #813968 6th Feb 2020 8:10pm
macfrank
There is no fuse in the live feed from battery to fuse box!
A serious omission in my view. A fuse is still on my to do list... Whistle
I think Darren's reason #2 is justified. Even if you put fuses at both ends, they would have to be >>60 Amps - maybe enough to cause a fire underneath due to fuel, oil, ...
Post #813988 6th Feb 2020 9:34pm
Martin
Site Admin
If you want to leave the original cable in place so it appears that you haven’t moved it, just disconnect both ends?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #813993 6th Feb 2020 10:00pm
grafty99
I'm pretty sure all 2007 onwards defenders have a 500A fuse on the battery terminal?
But as Martin suggested, leaving them in place disconnected might be a good idea. I think it would make them believe they'd disarmed the alarm, only to get a surprise when they open a door/bonnet and it goes off. Might be enough to spook them or at least alert the owner Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #814001 6th Feb 2020 10:43pm
The Fox
Cheers all.
Fitted but disconnected sounds like the way to go.
Post #814013 7th Feb 2020 8:16am
It's easy to set fire to a vehicle without blowing even a 60 Amp fuse. A 500 Amp megafuse isn't really a lot of use for protection since things will be really, really bad long before it blows.
You could always fit an extra alarm connected to the redundant exposed link cable that triggers if it is cut.
Post #814021 7th Feb 2020 9:21am
macfrank
The live feed is NOT connected to the 500A fuse! The wire goes off the battery terminal before the fuse.
The 500A is only for the starter/alternator feed.
But anyway, leaving the original feed disconnected seems the way to go.
Or you could even use it to trigger something when cut... silent alarm message, siren, blinding lights, tear gas... Whistle
(edit: just saw blackwolf had the same idea Smile if not as drastic Smile )
Post #814024 7th Feb 2020 9:43am
The Fox
This has got me thinking - I could fuse the old feed at 0.5A and fit a normally-closed relay in series to a battery-powered siren which charges from this circuit. Cut the under-vehicle cable = 120db of noise...
Post #814703 12th Feb 2020 9:39am
X4SKP
Exactly… Thumbs Up I know 'someone' who has done exactly this Cool
Why this is good, I would argue the best route even if using the security kit and not a DIY approach
is that if you are a victim of this design failure by JLR Embarassed and the cable is in place where expected
then is cut... this may help with ensuring the alarm is triggered when entering. SKIP
Post #814704 12th Feb 2020 9:55am
macfrank
Thumbs Up
Plus this: https://translate.google.de/translate?sl=d...em-Furie-5
Twisted Evil
Post #814835 12th Feb 2020 9:29pm
