Home > 130 > Best suspension set up
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I've read through the previous forum posts regarding suspension options but, I'm still undecided and with the new chassis on order I need to make a decision sharpish.
I've got a set of Britpart (I presume) HD Yellow springs on the shelf, I've run them in the past with no complaints.
I was considering running them with helper springs in the rear and genuine (ideally) HD front springs, but I'm stumped when it comes to the shock absorbers.
They're going on a DCPU which will be used for towing, collecting heavy loads, some overlanding and a large amount of unladen driving.
Any thoughts gratefully received. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #812321 28th Jan 2020 3:16pm
bear100
I’ve done a fair bit of research and come to the conclusion :-
Fox shocks (a bit pricey but not to bad, and quality is there)
Genuine springs or the new standard height Alive springs
Airhelper air bags for the rear.
Most people will only give advice on what they have fitted, quite a few have mentioned they fitted the Bilstein B6 and thought they were great, and then sat in another defender with Fox shocks and ended up changing the Bilstein out.
Best price so far is from Paddocks (forum members have %15off till the 31st (thanks Martin)) 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #812332 28th Jan 2020 4:51pm
Shroppy
I hadn't considered fox but will look into them! I've run their stuff a lot on push bikes and can't complain!
Thanks for the heads up on the discount, I think I'll be placing quite a few orders in the next month or so as the rebuild ramps up! 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #812369 28th Jan 2020 8:14pm
bankz5152
Old Man Emu will do a set to suit.
Koni HT Raid dampers - likely the best road going dampers on the market, adjustable and fully rebuildable. Instagram @defender_ventures
Empire Tuning - Agent
Post #812405 28th Jan 2020 10:40pm
jst
I have run several vehicles in the past with terrafirma, one, fox, koni shocks.
For general alround use ome get my vote. 3 of mine now running ome shocks.
Fox are good but better suited to vehicles been pushed more than mine are. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812582 29th Jan 2020 9:09pm
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
If you are towing this is what i have and it works
OME long travel springs front and rear
Fox extended shock
2" lifted Airbagman rear airbags
Airlift compressor
Adrenalin extreme rear trailing arms
Adrenaline tubular a frame
Adrenalin 6 deg front radius arms
3" rear propshaft
Double cardon front propshaft
You can also use the ARB shocks in place of the fox, they are just as good and slightly cheaper.
Its a great kit and allows the best of all worlds not to mention doesnt hurt the back when you are offloaded Can't leave well enough alone
Post #813712 5th Feb 2020 8:49am
