Home > Maintenance & Modifications > wires to the heater fan control in the central console
Eduardo
I there!
I already finished to repair the heater fan control: one of the cable clips supports were broken (Cable 1 in the picture)
After put all in place appear that I mixup some of the cables or something that control the vent dampers.
I can get air in the windscreen and in the foot but not in the round blowers.
Some of you remember the order of the 2 cables labeled red and yellow (cable 3 and 4 in the picture)?
As far as I can see in the picture that I took yellow should be cable 3 and red the cable 4 is that correct?
Or Ive missing another thing?
Thanks! Eduardo
Post #812300 28th Jan 2020 11:17am
Eduardo
Well,
A follow up of the problem:
Both cables are correctly located, so keep in mind the diagram when work in the area.
Red one change the position from the windscreen to the front. As far as I can see when I turn the knob the gears located in the heater noves correctly (see the picture).
So, the only posibility is that something is broken in the heater interiorand the damper doesnt move.
Anyone with a similar problem?
Should be possible to repair or I need the complete piece? (The complete heater cost more than 300 GBP and is working fine except for that.)
My other concern the access to the heater: I need to dismantle all the fascia. It's a complex work or can be done in a weekend with normal tools?
Cheers! Eduardo
Post #812408 28th Jan 2020 11:19pm
