Home > Technical > 2000 TD5 Diff Lock questions, have searched
Bodyman
United Kingdom 2000 Defender 110 Td5 HT Chawton White
I’m a new Defender owner, a 110 TD5 2 Door, the car was bought from the original owners, who have done 164k miles, and have never had diff lock engaged, all of the linkages seem to be operating as they should, but difflock won’t engage.
Can the shift fork seize inside the case ?
I will clean and lubricate the linkages as a matter of course regardless.
Also, when I’m in diff open, the diff lock light is ON, when I move the lever left to try to lock the diff, the light extinguishes,
Can anyone shed any light on either of my issues ?
Thanks in advance
Mike
Post #811092 19th Jan 2020 10:58pm
topless_matt
First thing first..... does the diff lock actually engage?
Jack up one wheel drivers front is usually easiest with the diff lock not engaged, the wheel should spin freely.
Now engage the difflock and spin the wheel, it should not turn, only a little bit until the slack in the driveline is take up.
If it is as above then the difflock is working as it should.
It is very u likely that the fork has seized internally as it is constantly lubricated when moving.
Do you know to the best of your knowledge or did they say if the transmission had been out of the vehicle?
Try the above and we can go from there. Hold my beer and watch this!
Post #811101 20th Jan 2020 6:43am
Bodyman
Hello mate thanks for the reply,
They didn’t mention the transmission ever being removed but obviously that doesn’t mean it hasn’t been.
I have tried what you said, the diff lock doesn’t engage.
Post #811111 20th Jan 2020 8:37am
Yes, unfortunately it is entirely possible for the internal parts of the difflock mechanism to seize, and since the selector fork is sprung against the actuating mechanism (it has to be this way) it is possible to have the situation whereby the linkage appears to work OK but nothing happens inside the box.
Unfortunately it is not easy to diagnose or fix with the transfer box in the vehicle.
Post #811129 20th Jan 2020 9:44am
OsloBlue
When i bought mine was siezed in High range as that was where it had stayed for 40000 miles.
Had to take mine off and un jamm it. I'm on IG: https://www.instagram.com/osloblue42/
Post #811140 20th Jan 2020 11:04am
Bodyman
Took the tunnel out, took off the linkage for the diff lock and removed the actuating arm with the 3xm6 bolts , freed up the detent shaft inside and cleaned and greased all of the linkages to the lever.
We have working diff lock !
Post #812105 26th Jan 2020 10:56pm
topless_matt
Glad it’s all working now. Sorry I did t reply to your previous response. Didn’t see it had a reply, good technology on iPads Big Cry Hold my beer and watch this!
Post #812127 27th Jan 2020 7:19am
hank
Glad it was nothing too serious and you got it sorted relatively easily Thumbs Up > 110 XS Double Cab
Post #812129 27th Jan 2020 8:16am
