Home > In Car Electronics > Light Bar Fuse Melting |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 |
Sounds like there is a short somewhere in the circuit. Is there any condensation or moisture in the lightbar? Hold my beer and watch this!
13th Jan 2020 9:21pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
Is it definitely 12A at 24V? If so, that’s 24A at 12V.
If it’s 12A at 12V, your fuse could be a little bigger and still be safe.. try 18A. 2014 Keswick Utility 2.2 |
13th Jan 2020 9:28pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 895 |
I did wonder if there was a short but it was professionally installed not long ago. No condensation in the bar.
Yes it’s quoted as 12A at 24V. OK then, I’ll try an 18A and see how that goes! Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
13th Jan 2020 9:39pm |
If it’s rated 12A @ 24V then it will draw 24A on a 12V system like the defender, so you’ll need a much bigger fuse plus make sure your wiring and relay are up to the job, I know you said it was professionally installed but if they fitted a 15A fuse I’d be getting a second opinion on the whole install. 2014 Keswick Utility 2.2
13th Jan 2020 10:00pm |
OK thanks. It seems like the fuse is probably far too small for the light bar. It’s a Mobile Centre harness that I had made up so it should be good quality. I think I’ll start by going up to a 20A fuse and see how that fares. Charlie
13th Jan 2020 10:22pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2149 |
30 amp fuse. Instagram @defender_ventures
Empire Tuning - Agent |
14th Jan 2020 6:16am |
Sorry misread the 24v part. As above needs a suitable fuse as the 15 is very under rated. However as above I would check the whole install if it was supplied fitted with a 15 amp fuse. Hold my beer and watch this! |
14th Jan 2020 7:01am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4205 |
What light bar have you got? Must be like staring into the sun. 2007 110 TDCi Station Wagon XS
14th Jan 2020 7:23am |
OK, seems the general consensus is that the fuse is too small. I’ll have a quick check over all of the wiring.
It’s a GRP 54” light bar. It’s good for illuminating pretty much everything and also for burning out the eyes of oncoming motorists. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
14th Jan 2020 8:10am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
If it came fitted with a 15A fuse then the whole loom might not be rated for the current you'll be pulling through it. If you put a big amp fuse in wiring that isn't designed for it then the wiring becomes the fuse.
Things then start getting messy 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
14th Jan 2020 8:19am |
That is a concern . . . I’ve sent Mobile Centre an email asking what the whole harness is rated to. Charlie
14th Jan 2020 8:29am |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 |
Be aware a blade fuse only blows at DOUBLE the rating on the fuse, so your 15a will only blow completely at 30a, which is why it was starting to go. Always ensure that the cable is rated for more than the face value figure of the fuse, and try and keep that fuse rating as close to the current draw of that circuit. You will find that any good quality automotive cable will handle spike loads of double the normal rating for five seconds or less, and after that point the fuse blows anyway. North Cumbria Search and Rescue - Team Leader
14th Jan 2020 8:59am |
I think I need to wait and see what Mobile Centre have to say about the harness. Once I’ve had that info I can look to swap the fuse or the whole harness. But it’s clear now that a 15A fuse is too small. Charlie
14th Jan 2020 9:27am |
I’ve just been on the phone with Mobile Centre who are going to make me a new harness. They’ve said that the harness is being overloaded and hence the fuse is melting and not blowing. The harness I currently have is rated to 15A. The GRP 4x4 light bar is probably drawing about 42A. GRP told me it draws 4A in an email whilst they quote 24A on their website but the figures for Wattage make a figure of around 42A. Charlie
14th Jan 2020 11:08am |
