![]() | Home > Technical > Freewheeling , how much ? |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Sako
Thank you for taking the time to help out . I absolutely know what you mean about passing burning smells and thinking that they may be emanating from your own car ! You’re probably right , I ought to start undoing bits , luckily the pre vibration list is smaller than the post vibration list ! I’ve tried dropping the props in turn and it does improve things but it didn’t matter which one, they both had the same result https://www.instagram.com/hustynminepark/ |
Thank you Sako
I've tried eliminating the rear diff by removing the driveshafts and locking T_box and it improved in the same way that removing the prop did , I can therefore assume that it is not a rear diff issue. As you suggest , the front is not really an option to remove the driveshafts but I did try with hub flanges removed whilst on axle stands, that made no difference. All of the below have been replaced since I've had these reverberating issues , so it would be an utter coincidence of replacing one bad part with another , although I know it does happen ! - Prop shafts: I've spoken with Gwyn and he's adament that they leave the shop perfectly balanced, really nice chap and very helpful. They are however twice the weight of the standard ones ! - Transfer box: Did Ashcroft's do the build? yes ashcroft built the box, I am suspicious of it as it seems stiff to engage diff lock and to turn props by hand , let alone against each other , I've put this down to the ATB - Front & Rear Diff: Who did the build? Maltings offroad supplied but I dont' know their source - Driveshafts & CVs: What brand? Bearmach - Assumed you used Timken bearings and have checked for play / tightness? yes Timken and no play anywhere, seem perfect. - Brake pads - unlikely to cause an issue if they're not rubbing / getting hot but I might be wrong Pads are all rubbing when on axle stands but not obvious on the road or getting hot - Transfer box mounts: They haven't been overtightened / or the rubber's too stiff? [i]I wasn't aware they could be overtightened , rubber seems nice and supple I don't think a video would help diagnose as the noise is so deep and only happens when I'm driving ! What I may do is take one of it on axle stands and all wheels driving .[/i] https://www.instagram.com/hustynminepark/ |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Is the front prop double cardan?
Pumas suffer with front prop angles causing vibration because of the angle of the engine /gearbox relative to the axle ![]() P. S any lift above standard ride height will make it worse 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
No it’s standard height , although if double Cardon props weren’t quite so expensive I’d give it a go !
The angle that the front prop connects to the Diff flange does seem unnecessarily excessive https://www.instagram.com/hustynminepark/ |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
I would be thinking wheels/tyres, warped brake disks, propshafts.
Can you borrow known good wheels/tyres? Or maybe eliminate one by one by using your spare? Propshafts you can eliminate one by one and drive in difflock Discs, you will feel/hear thing under braking > 110 XS Double Cab |
Thanks hank , discs are new as our props . I haven’t tried a new set of Wheels and tyres though. Only ones I have are off a series 1 ! https://www.instagram.com/hustynminepark/
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
I have an ATB in the TC and noticed more effort to spin the prop flanges than a standard box. This was when the box was on the bench.
Difflock on mine is ok, I needed to adjust it so stayed in but other than that OK. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Very interesting thank you Exo https://www.instagram.com/hustynminepark/
It does almost feel like it’s stuck in diff lock but I’ve tested it and it’s not . https://www.instagram.com/hustynminepark/
I think its the design of the ATB. I am sure I discussed this with Ashcrofts and its as they by design. 1999 Defender TD5 110
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1233 ![]() ![]() ![]() |
I'd go down the route of borrowing a set of wheels and tyres to try out. Eliminate that first. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Agreed , I don’t think it is but daft not to try !
Just had it up on axle stands and noticed that when the engine was running and gearbox in neutral , the wheels were turning very slowly . I could stop them by hand . I’m imagining this is simply fluid in the gearbox applying pressure to the gears etc ! Putting the transfer box to neutral stopped them https://www.instagram.com/hustynminepark/ |
That seems a bit odd to me. I can't see an actual reason why a gearbox in neutral would cause the output shaft to spin. Wonder if one of the shafts could be bent / misaligned.
If swapping wheels doesn't help then maybe removing the PTO cover, transfer box in neutral and gearbox in neutral. Can you spin the PTO shaft by hand freely, are there any tight spots. Maybe try the same then in all the gears. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Hi Sako
Thank you , what do you mean by PTO cover ? https://www.instagram.com/hustynminepark/ |
