Home > V8 > Radiator with oil cooler built in - good idea or not?
Hufflepuff
I need to obtain a radiator for my Rover v8 project, and see that Allisport do one with an oil cooler built in:
https://www.allisport.com/shop/performance...hermostat/
Assuming this is intended to be used with a engine oil, and not for automatic transmission cooling, would you think this was a good idea for the Rover v8, or not?
I would like to maximise my cooling potential, both offroad and when cruising along at motorway speeds. It looks like you can get a sandwich plate which sits between the oil filter housing and engine, where you can get a feed off to go to an oil cooler.
My concerns are:
(a) Will the oil filter still fit? From memory when I took the original 3.5 out, the filter looked quite close to the front chassis.
(b) Is it just another point of failure waiting to happen, eg. another leak point or more catastrophic failure point?
The engine which is going in is a 4.8 litre fuel injected unit from ACR, so has the potential to generate quite a lot more heat than the original 3.5.
Cheers!
Chris. 2005 Td5 90 XS
1989 V8 110 CSW
Post #809012 6th Jan 2020 1:52pm
rallysteve
I just used an original radiator from a Land Rover 2.5TD which has the cooler built in. i think they are quite a neat installation as you get some of the benefits of an oil-to-water and an oil-to-air cooler without any packaging issues.
You will want to make sure you have a thermostat on the oil cooler supply pipes from the pump. My serpentine engine had one from new as the discovery also used a cooler built into the radiator.
Post #809013 6th Jan 2020 2:00pm
Hufflepuff
Thanks for the reply Steve. I will go ahead and order the one with the oil cooler then - I didn't know that the Discoverys had them from factory, cheers! 2005 Td5 90 XS
1989 V8 110 CSW
Post #809137 7th Jan 2020 8:46am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
+1 - my V8 is D1 Serp and has a DTurbo rad with oil cooler. JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #809210 7th Jan 2020 3:33pm
jst
yes def worth doing. those Allisport V8 rads really do shift some heat, my advice is get one with the twin fans and shrouded. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #809269 7th Jan 2020 8:32pm
V8GPC
The Defender 50th cools the oil in the radiator.
"The V8i engine uses a pressurised cooling system and cross flow radiator which is supplied from a separate expansion tank. The coolant radiator also incorporates a section at the side for cooling the engine oil. The transmission fluid cooler is mounted
below the radiator."
Not cheap though
https://www.allisport.com/shop/performance...-nas-spec/
Post #809487 9th Jan 2020 6:39am
Romadog
Cheaper to buy a Britpart one Whistle
Post #809609 9th Jan 2020 7:39pm
My old 3.9 EFI in a 110, I fitted a turboD radiator. Just had to change the oil pipe unions as the TD thread was different to the V8.
Apart from that it bolted right up. But..... the "cooling" bit of the TD rad is just a pipe going in and out, from top to bottom (or bottom to top), nothing mega or special.
but it worked fine with mine. and I used to give it some stick too... then tranferred the whole drivetrain into a 90, and gave it more stick....
Post #810902 18th Jan 2020 8:31pm
