Home > Technical > Exploded diagram of the gear change on a 2015 defender
Sulisuli
Does anyone have a diagram that shows the components that make up the gear change on a 2015 Defender gearbox, I have managed to damage the rubber grommet type piece when installing the slickshift and I need to order a replacement part.
My money is on DorsetSmith being the saviour on this Bow down 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806103 13th Dec 2019 9:32pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
https://www.lrworkshop.com/diagrams/land-r...ange_45150 WARNING.
This post may contain sarcasm.
Post #806104 13th Dec 2019 9:44pm
Sulisuli
Bow down Bow down your a gent Zed thankyou. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806105 13th Dec 2019 9:46pm
Sulisuli
Guess I’m going to have to buy Part 1 Big Cry 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806108 13th Dec 2019 9:50pm
Zed
I didn't look at that diagram properly before posting.
Do you mean the selector cup? https://www.onlinegearboxparts.com/product...nylon-cup/ WARNING.
Post #806110 13th Dec 2019 10:04pm
Sulisuli
No unfortunately, there is a rubber gaitor that has spilt on the selector assembly. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806111 13th Dec 2019 10:05pm
Zed
I think I know the part you mean but can't remember it's name. Dorset will no doubt be along in a mo to give the correct info. Leave it to the professionals an' all that! WARNING.
Post #806114 13th Dec 2019 10:21pm
If it's a clean split, try superglue before buying an expensive complete assembly. Darren
Post #806127 14th Dec 2019 7:54am
dorsetsmith
witch rubber grommet Question
6- ULN50020
7- TSF 50030
8- TSF50020
!6- LR052893
Post #806140 14th Dec 2019 10:07am
Sulisuli
It’s to badly damaged Darren so think I am going to have to purchase Part 1 as per Dorsetsmiths diagram below? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806181 14th Dec 2019 4:28pm
I know the part you mean and you are correct that it is piece of the Part no: #1 on the diagram and NOT sold separately.
(Rubber gaiter above the selector ball, over the selector shaft but retained under the whole selector assembly.)
Mine wanted changing ideally too but not easily obtained, if you go to a breakers or eBay that's all very well but it won't be a new part either.
Very annoying issue really as it's a single part.
I tried tracking one down, but was categorically told that it wasn't available as a part on its own.
Confused TheThunder Rolls🇬🇧🇺🇸
Post #806186 14th Dec 2019 4:44pm
Sulisuli
Steve your a gent Thankyou for the explanation Thumbs Up that’s going to be an expensive bloody grommet!! 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806201 14th Dec 2019 5:49pm
dorsetsmith
Post #806208 14th Dec 2019 6:14pm
dorsetsmith
Pic of this grommet
you need grommet on the lower ball will investigate
Post #806264 15th Dec 2019 8:41am
Sulisuli
Dorsetsmith Bow down Bow down your a legend. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806284 15th Dec 2019 11:22am
