Home > Td5 > Wipers suddenly stopped - not fuse?
Page 2 of 3 <123>
Gareth
That’s excellent, thank you very much indeed. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #805664 10th Dec 2019 5:38pm
ARC99
Mine did the same thing a couple of months ago, both fuses =okay relay swapped out = still not working. turned out to be the motor was dead. Indy changed motor and while at it changed the rack as showing signs of wear. Don't make old people mad.
Richard
Post #805776 11th Dec 2019 9:51am
Gareth
Well 🥁
Seized wheel box!! Absolutely seized solid.
The fact that the left hand wheel box was seized means getting the whole thing out becomes a real dismantling job on the dashboard. Basically I had to remove the whole top, middle, centre panel and instrument binnacle.
Now to test if the seized gear has blown the motor. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #805810 11th Dec 2019 2:29pm
dorsetsmith
then you get new wheel box in place, pack the black boot with SILICONE Multi Purpose Grease to give the wheel box longer life and keep water out
black boot right hand side pic
Post #805813 11th Dec 2019 2:54pm
4RF RDS
Its old , might as well just put a new motor in there anyway.
Glad you sorted it. Cheers Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #805818 11th Dec 2019 3:30pm
Gareth
Yes, I think it’s such a Censored to get to, do it properly do it once! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #805820 11th Dec 2019 3:34pm
4RF RDS
Shocked I forget that just baout everything is easier to get at in my LHD Whistle Smile 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #805821 11th Dec 2019 3:45pm
dorsetsmith
Wiper replacement 2004 model see below
https://www.defender2.net/forum/post528446.html
Post #805851 11th Dec 2019 8:05pm
RobKeay
I am just in the process of doing mine. The dashboard is quite unnerving to pull apart.
I am told that Landrover allow 16hours to carry out the job. So I keep reminding myself how much I am saving.
Post #805854 11th Dec 2019 8:25pm
ARC99
Mine was done in 5 hours by the Indy I use, I can just imagine a stealers doing the job in less than 16 hours, parking the vehicle up then charging 16 hours labour. Don't make old people mad.
Richard
Post #805916 12th Dec 2019 10:30am
dorsetsmith
you can get to left hand wheel box with out removing hold dash
Post #805985 12th Dec 2019 5:35pm
4RF RDS
In my LDH 110 I was able to change both wheel boxes with only removing the top dash pad. Took about and hour and half. Its fiddley but doable. Done it few times on different Defenders. Not sure how different a RHD would be? I see you can easily access the left side wheel box. 👍🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #805987 12th Dec 2019 5:47pm
dorsetsmith
Had too change park switch today as wipers had stopped parking then switch off, took the pic to show that you get too the left hand wheel box with most of the dash in place
manage to do the job hr 1.30 with tea brake at the end Thumbs Up and rain brake too
Post #805994 12th Dec 2019 7:38pm
markb110
My local dealer charges 135ish per hour plus VAT . 16 hours labour, may as well wait 5 years and buy a second hand New Defender .
Did mine a couple of years back, still have the left over screws ready for next time Laughing
Post #805999 12th Dec 2019 8:32pm
Gareth
Finished the job last night. Took me about 5 hours all in. I could have got away with just changing the left wheel box, but decided to swap it all (except motor) as the right wheel box was stiff. Also put a new rack cable in as that was worn where it had been running on the gears.
I reckon the dash has been apart before, as I found a few holes and clips with missing screws and has to raid my supply of spares to finish the job.
Also had to hunt out the radio code! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #806063 13th Dec 2019 2:10pm
Page 2 of 3 <123>
