Home > Puma (Tdci) > gear stick
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
gear stick
im trying to get to the bottom of this gearbox chatter and vibration and im noticing that the gearstick vibrates quit bad anyone els had this problem
Post #5351 8th Dec 2008 5:17pm
AndrewS
Post #5352 8th Dec 2008 5:26pm
mse
If your on about the gearstick vibrating and causing a noise - i get it at some some revs and apparently its the selector plate that needs replacing as its not holding tightly enough. Mike
Post #5354 8th Dec 2008 5:41pm
simonpuma90
when your doing about 60 the stick is shaking side to side quite bad
Post #5365 8th Dec 2008 9:02pm
AndrewS
Yep Thumbs Up
I got a new box but the new one does it Rolling Eyes
Post #5366 8th Dec 2008 10:03pm
simonpuma90
I think Land rover are starting to take the p**s out of us you know
Post #5368 8th Dec 2008 10:06pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I notice chatter in 6th at about 110kph when backing off the throttle. When re-applying power it is there again, briefly. I mentioned it to the dealer and he said it is a transfer case bearing. However the noise is there again momentarily upon starting, but only when the clutch is not depressed (the handbook says to depress the clutch when starting). This could not possibly be the transfer case as the gears would be stationery with the main gearbox in neutral. It could well be the selector plate,
Austen.
Post #5376 8th Dec 2008 11:42pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
I think "simonpuma90" has a valid point. I've been without my Puma 90 for 3 weeks and a day now while they (the dealer) sort out gearbox and driveline issues. Land rover have washed their hands of it saying my contract of sale is with them not LR Thanks a bunch for your help LR!!!. They're now apparently waiting for a special transmission tool from SPX.
Bosun.
Post #5377 9th Dec 2008 7:12am
mse
Yes thats because its the selector guide - which wont have been replaced and thats what you need replaced. Mike
Post #5411 10th Dec 2008 1:13pm
