Home > Td5 > Courtesy Interior Lights Issue |
thefender Member Since: 25 Aug 2019 Location: kent Posts: 28 |
I was original OP - I only did what you have done and it resolved it. If settings are returning to "as was" I can only think something is going wrong at the confirmation or save stage - although for the life of me I don't recall how that bit works - from your description that sounds like the prob. Is it possible for you to adjust something else, not on the Alarm side to see if it remembers that setting?
29th Oct 2020 5:40pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 930 |
Turns out it was me not the Nanocom. I wasn’t letting the write settings finish... its all set now. Appreciate the quick response.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
29th Oct 2020 6:13pm |
