Home > Technical > Oil leak g or t box
jst
Oil leak g or t box
noticed a patch under the vehicles, whats the general verdict g or t box.
2011 vehicle 73k, ashcroft output shaft fitted @ 30k.
i am on t box input seal failing, is this a known thing/common? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #805454 9th Dec 2019 12:24pm
rallysteve
Looks like it might be the intermediate shaft o-rings on the Transfer box. Mine used to be like that, the oil goes everywhere!
There is a hole in the casting on the gearbox which oil that leaks between Transfer and Main Box seals can escape though which is on the O/S bottom of the casting.
Post #805464 9th Dec 2019 1:53pm
jst
yep its that hole, shown, that the oil is coming out of. i am pretty certain its EP90 so from the T box. but could be either g or t in there. am going to check level in T box and go from there. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #805475 9th Dec 2019 2:59pm
rallysteve
Ah yes, my apologies. I hadn't registered that it was an 6spd box rather than the R380 i am used to!
Post #805477 9th Dec 2019 3:29pm
jst
wasnt meant to criticise, thank you for point out, just wondering if i drop the t box or take the whole lot out (if it gbox seal easier probably) and then do the clutch too. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #805507 9th Dec 2019 7:17pm
Mdm
drop the t box fix seals and fresh oil and see how it goes for me
becoming more common to leak from here as the boxes get older.
Post #805510 9th Dec 2019 7:20pm
jst
also my thoughts and looks like ep90 to me too. plus it took 1/4 litre topping the t box up earlier today Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #805517 9th Dec 2019 7:31pm
ickle
Not ever having seen one, but does the Ashcroft output shaft conversion 'leak' oil to enable its own lubrication? Although that does look like a lot of oil!
The favourite cross shaft leak - is it outside of the output shaft housing, or could it be leaking inside of the housing`/ `the O rings are peanuts so if you're going to drop the box to do the seal, might be worth doing the o rings at the same time.
Keith
Post #805541 9th Dec 2019 8:36pm
jst
ashcroft kit uses oil from gbox to lubricate it yes. it uses a t box seal from memory too.
i reckon its EP90 from t box leaking past input seal into the intermediate housing.
as darren says got to be t box off first and go from there i reckon. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #805554 9th Dec 2019 9:46pm
ickle
I think I used 4 lengths of m10 studding to put the transfer box back on with to avoid damaging the seal - its a heavy lump balanced on a jack
Best of luck!
Post #805556 9th Dec 2019 9:52pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
The acid test is does it smell of EP or of the gear oil from the G box?
The article on Ashcroft's site doesn't specify a different seal so having that one and the common ICV100000 for the T box as it's out might not be bad idea.
The MT82 output seal is a Lr058800 or... if you want genuine but not £30 LR genuine then The ford number is 1476743 is about £10 less for the same seal just not in LR packaging. Rolling with laughter Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #805562 9th Dec 2019 10:36pm
jst
cheers, yes have the T box seals on order and was just about to google the Ford number for the gbox output, thank you for the timely link. £20 ish from ebay for gen ford.
smells and feels like EP90 to me. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #805613 10th Dec 2019 12:03pm
ashtrans
Site Sponsor
Hi James,
let me know when the transfer case is off if its the output shaft kit,
some of the early ones leaked as there was little clearance between the ali collar and the inner shaft,
In some cases this clearance is not enough as I naively though the input gear would be directly inline with the MT82 output shaft, often its not. Dave
Post #805782 11th Dec 2019 10:24am
Kudos Dave Thumbs Up Still one of a handful of companies who I openly champion.
Post #805789 11th Dec 2019 11:37am
jst
gbox oil it turned out to be. i seem lucky though in that the gbox and t box do line up so not coming from Daves kit. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #806889 19th Dec 2019 3:09pm
