Home > Td5 > Grinding when come of gas |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5711 |
I would start diagnostics with changing oil on the boxes and diffs. It could be that they are empty, the oil is knackered, or you may find bits of debris, that indicate that you have an issue.
Andy. |
9th Dec 2019 9:06am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2229 |
Check the idler/tensioner pulleys on the alternator belt.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Dec 2019 9:29am |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 896 |
We had something similar on our Puma. Sounded like the gearbox was about to disintegrate. Happened after we put a lift on the vehicle. Double cardan prop solved it. Might be worth checking prop UJs as they’re easy to look at and cheap to fix. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
9th Dec 2019 1:19pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Transfer box idler thrust bearing?
9th Dec 2019 6:44pm |
