Home > Puma (Tdci) > A hard to describe problem |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 298 |
Cheap fuel filter or air getting into the fuel system?
25th Nov 2019 12:16pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3745 |
Do the dashboard lights go out when the engine cuts out (all dials zero?)
I had this, random cut out, no funny engine / juddering etc just cut out for a split second. Fix was a new steering ignition barrel. No fault logged as it was possible before it got to that... Has worked fine since |
25th Nov 2019 2:52pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
I believe this could also be an issue with relay connections under the seat. A mate had this on a TDCI everytime he turned a sharp corner and I'm sure he said pinching up the socket connections solved it.
25th Nov 2019 5:24pm |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 |
The dashboard lights stay on and even the dials don't go to zero. However when the vehicle comes to a standstill then the ignition lights (the pre start mode red lights) come on. And she comes to life immediately when i re start the engine. |
27th Nov 2019 11:35am |
The fuel filter is original Land Rover. Will need to check if air gets in. |
27th Nov 2019 11:36am |
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 |
I’m having a similar issue, but dropping through idle to stall instead.
I’ll watch with interest how yours develops! https://www.defender2.net/forum/topic69868.html |
28th Nov 2019 10:17am |
Have you found any water in the fuel ?
28th Nov 2019 10:34am |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Could this be the VCV valve?
2nd Dec 2019 4:18pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17355 |
^^^ Very possibly, classic VCV symptoms.
2nd Dec 2019 5:59pm |
Defender13 Member Since: 19 Dec 2016 Location: Adelaide Posts: 7 |
Have a look at this, maybe it will help to assess the situation. As you have the 2.4 Puma, you do not have the diesel delivery pump insode of the fuel tank but directly on your common rail delivery pump:
Hopefully it helps. |
4th Dec 2019 2:03am |
So it finally turned out that my problem was caused by a faulty common Rail pump which was replaced and I have had no further instances of the engine cutting out on me.
11th Feb 2020 3:31pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Thanks Def Junkie, it's always good to know the causes of these spurious problems Defender 90XS SW
11th Feb 2020 3:41pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
ouch !
11th Feb 2020 4:39pm |
Tricky to replace??
11th Feb 2020 6:12pm |
