![]() | Home > Technical > 300tdi bottom hose size |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1864 ![]() ![]() |
I have a spare somewhere that I can measure if I can find it.
But I thought I'd also suggest an alternative, which is to use a siphon hose into the radiator, other end into a collection bucket or an old Adblue bottle. There's a version of the 'trapped jiggly ball' siphon kit which will fit down the radiator plug. This way, you can certainly get most of the coolant out without removing the bottom hose at all. I think I picked this up from a youtube video somewhere. In fact, just thinking about it, a drain in the bottom hose would need to be pretty trustworthy, or it would be the worst possible place to have a coolant leak. Siphon hose like this sort of thing https://www.screwfix.com/p/laser-jiggle-siphon-hose-20mm-x-1-75m Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
It is risky and I had thought about a siphon but thought if I had a drain plug I could give the radiator a flush out every time I changed the coolant, but thinking about it now, I’m only going to need to do that every couple of years so maybe I’m asking for trouble. I’ll have a better look at proper siphons.
Thanks donmacn. |
![]() I think the critical thing is getting something to fit into the filler/radiator plug. I have two of those siphon things, one fits and one doesn't. Last time, I couldn't find the one that fits, so ended up with the old-school approach of sucking coolant up a hose. Yuk. You need to fiddle the hose right down into the bottom corner of the rad, and opening the expansion tank cap, and the thermostat housing plug lets air into the system so that the coolant drains better into the radiator. There's usually something left in the pipes, but I reckon I'll get about 80-90% of it out. In fact this is a handy reminder to find the one that fits - as the engine's coming out later this week! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
Here's another idea:
I cut the bottom hose on the leg that goes to the expansion bottle about 50mm from the main hose and fitted a 15mm solder ring tee with a compression fitting service valve on the third leg. The open end of the valve is capped with a compression blank to keep the crud out and as a failsafe for the valve. When I need to drain the coolant, I remove the blank, fit a tube with a hose attached, place the hose in a suitable container and open the valve. The coolant ends up in the container and not all over the front of the car and the drive. On a plus point, if you're draining for something other than a coolant change, it keeps the coolant clean and re-useable. Paul |
