![]() | Home > Technical > 4 pin diff question |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Can I fit a 4 pin diff to the front of a 2008 Defender as a direct replacement?
I'm told not if you have ABS but I don't understand why. Peter |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5822 ![]() ![]() |
Yes as long as it is the correct diff.
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
I cannot see why the fitting of a 4 pin diff would make any difference to an ABS equipped vehicle.
The function of a differential is not affected in any way whether it is 4 pin or 2 pin It is not a Defender, it is a One_Ten |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
After the 2 pin diff's long history of strong and dependable service with the lesser engines ![]() No problem with fitting any sort of diff with ABS in my view. Any open diff has the same function, a torque biasing system will almost certainly help the ABS, and a fully locking diff will just mean the ABS doesn't function when the driveline is all locked up. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17622 ![]() ![]() ![]() |
True, but don't forget that the TDCi is the torquiest engine ever fitted to a mass production Defender, and also produces a lot of torsional vibration, both of which really hammer the transmission. |
It's interesting (if a little OT) to note that they upgraded the front diff to a four-pin, and then downgraded the centre diff to one made of cheese to compensate
![]() 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
