![]() | Home > Technical > Best wiring routing from behind dash to the cubby box |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4251 ![]() ![]() ![]() |
I've run a cable out of the cubby and then under the carpet on the right side of the trans tunnel toward the foot well, past the handbrake, where it emerges under the dash and straight up into the centre area of the dash. It's dead neat, no holes except the one to get the cable out of the cubby. 2007 110 TDCi Station Wagon XS
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
I've done the same as Bluest, mine is a TD5 so it runs behind the fuse box cover and up to the dash with the main loom. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
As bluest said. The mud extended A pillar trims are great but they have their limits even. There’s no way you could fit a whole loom down.
On a Puma there is access each side of the trans, between there and handbrake is the most and a void the the left and up from the clutch pedal in a RHD. It should all high under matting. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
