![]() | Home > Technical > Defender 2.2 Puma - Oil in Charge Air Cooler Exhaust Duct |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1451 ![]() ![]() ![]() |
Hi,
It is normal to get oil in the inlet duct, I think it will be from the crank case breather. Over time it builds up and can appear to be excessive. After the EGR valve, the exhaust soot mixes with the oil and this looks terrible. Clean the pipes and check them in a few months time, if you are concerned about it. |
Tumbiri Member Since: 01 Nov 2016 Location: Caribbean Posts: 52 ![]() ![]() |
Thanks for the reply. So that I understand correctly, is what I'm seeing oil that starts off in the inlet duct (from the breather) and eventually works its way through the turbo charger and charge air cooler to the exhaust duct? You mentioned only the inlet duct so I'm not too sure.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17622 ![]() ![]() ![]() |
Fit a Provent filter and this should stop.
Use the forum search facility (search "Provent") for more information. |
Thanks, will do.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8181 ![]() ![]() ![]() |
Dont worry about it.unless you have oil usage. Cheers
Thanks JST; my conclusion is, it's not a concern. While I have you; I don't see a Maintenance Schedule item to check the PCV valve. Do you know how often this has to be checked?
