Home > Puma (Tdci) > fob/ indicators
dcpallets
fob/ indicators
hi i set my alarm with fob , indicators flash . But when i unlock i do not get a flash from the indicators, any answers would be greatful 2012 puma
Post #801107 6th Nov 2019 8:21pm
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
Sounds like fob battery. Check the appropriate owner's manual section, it gives the symptoms and the change procedure.
Post #801109 6th Nov 2019 8:30pm
dcpallets
fob/ indicators
have two fobs one doesnt flash indicators on unlock, then used the other but used to flash indicators when you unlock , now that doesnt , ,
Post #801110 6th Nov 2019 8:34pm
skidrov
I would replace both batteries. Even if wrong, not much to loose, easiest fix. But, check/follow the owners manual process.
Post #801113 6th Nov 2019 8:37pm
Co1
Batteries
Post #801147 7th Nov 2019 6:01am
AMBxx
Is the lack of flashing by design to let you know the batteries are nearly dead? I recently had the problem of not being able to unlock one morning - turned out to be the battery in the fob. 2 weeks later I'd have been on holiday and have been in a real pickle.
Post #801166 7th Nov 2019 9:01am
skidrov
Yep, all in the manual. Guess how I know... 😋
Post #801172 7th Nov 2019 9:25am
AMBxx
I take it you looked after the battery went flat? Very Happy Very Happy
Post #801174 7th Nov 2019 9:52am
