Home > Maintenance & Modifications > Transmission Noise - This could be expensive! |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4222 |
They are Conti Cross Contact, about 7 years old or so. If it were tyres I'd expect it to happen more often and in a wider range of circs. I rotate my tyres at service and that didn't seem to alter the issue. 2007 110 TDCi Station Wagon XS |
23rd Dec 2022 2:57pm |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
Thread revival!!
Bluest does your truck still make this noise? Cheers, Matt |
18th Apr 2024 9:12pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 565 |
Had a quick read through this and my immediate thought from your description which you describe as just a noise.. No other symptoms and hasn't happened for ages... Is there any chance it could be related to your viscous fan?? Assuming that that's what you have..
The different noise I can get from mine is very noticeable if I'm close to the truck when it changes note.. You say it's temp related so just wondering if that had been considered daft as it may sound |
19th Apr 2024 6:06am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3437 |
I actually wonder if this is just gear chatter, as it only happens at very light load. When it is warm, oil viscosity drops, things expand and loose some pre load. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
19th Apr 2024 7:43am |
