Home > Maintenance & Modifications > Heater air intake vent
mini Anaconda
Over the last few weeks I have had some condensation in the heater of my Ninety after heavy rain, so after clearing out the drain plug under the plastic grille, I thought about fitting either a vent on the top or snow cowl.
I settled for the Britpart air intake vent (DA4000) as I preferred the look of this to the snow cowl, but after fitting I noticed the output of the heater dramatically reduced, I assume due to the smaller vent intake. I thought this might have been offset by more airflow going through when driving with the vent on the front but clearly not. I removed the vent today and the heater output returned to normal. Confused
The vent is well made for the price, but not a good use of £12. Rolling Eyes BORG - Bucks & Oxon 4x4 Response Group
Post #800636 3rd Nov 2019 7:55pm
Sulisuli
The opening in the vent is considerably smaller than the original flat top, but the “ram” effect should have improved it I would have thought.
I have just removed my KBX wingtop and replaced it with a snow cowl I was somewhat unsure about the appearance but I’m delighted with it and the heater output is identical so win win
 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #800638 3rd Nov 2019 8:03pm
mini Anaconda
That's interesting. I'm not sure how the mechanics of a Puma heater compares to that on my 1989 model, but I would have thought the 'ram' effect would have offset the smaller vent.
Maybe try a snow cowl next. Embarassed BORG - Bucks & Oxon 4x4 Response Group
Post #800640 3rd Nov 2019 8:09pm
L110CDL
I have a snow cowl on my 300 Tdi and have not noticed any reduction of the heat output compared to the original vent Thumbs Up Clayton.
Keeper.
Post #800654 3rd Nov 2019 8:47pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Re: Heater air intake vent
Knock the fanny drain in the bottom of the heater out completely, I have done on several of mine. The drain blocks with mud, and then water sits in the bottom causing misting up. It's completely pointless. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #800683 3rd Nov 2019 11:29pm
^^^^ I put mine back in after a while and keep them clean.
Reason being is you will draw warm air in and anything in the engine bay if they aren’t present.
So I prefer to keep them often cleaned out. KEEP CALM AND Drill ON
Post #800684 3rd Nov 2019 11:34pm
jst
Ram air has negligible benefit below 90mph Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800696 4th Nov 2019 7:56am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I think you're thinking of RAIs and snorkels.
Post #800778 4th Nov 2019 5:55pm
jst
No I wasnt, I was thinking back to an engineering project. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800784 4th Nov 2019 6:35pm
BenB8man
Ah apologies. Embarassed I assumed you were thinking back to the project that Pete from BAS did on different air intakes vs Ram air effect.
I'm sure I've heard a few people say that the little air scoops for the heating were quite good, I doubt they were talking about it above 90mph.
Post #800803 4th Nov 2019 8:14pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I Have a snow cowl fitted- great at keeping leaves out.
Prior to fitting the blower was like an asthmatic blowing through a straw.
Its still very much like an asthmatic blowing through a straw but doesn't smell of rotting vegetation now.
Chris
Post #800806 4th Nov 2019 8:37pm
htb2
Wales
At least its better than a Series 3 one, which is in a low pressure area at speeds over 60 and sucks air out of the heater.
Post #800807 4th Nov 2019 8:38pm
ericvv
Interesting. When I had my standard intake grill, I had some airflow from the ventilation/heating even without turning the fan on. That airflow increased with speed of course. Now with my snow cowl ( same as yours) I have zero airflow at any speed without using the fan. The fan works perfectly at either of its three positions, just like before, so it is not a case of any blockage, just means that the Entreq snow cowl kills all ram effect. Not a problem, just different from your experience.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #800812 4th Nov 2019 8:57pm
I think that the shape of the wing means that there is no ram effect with the heater input since the location of the intake, midway along the flat upper surface, will be in an area of low pressure. Before fitting my snow cowl, my heater would deliver a small amount of air without the fan on (probably due to the coanda effect) but with the snow cowl then there is no air without the fan. There is however also no smell of decay and decomposition either.
Airflow or lack thereof is not a problem as far as I am concerned, I just leave the fan on speed one (or above) if I want air, and at least if I don't it is easy to switch off without having to use the recycle setting.
Overall the heater on the TDCi continues a long tradition of functional inadequacy that has been an part of Land-Rover ownership since 1947. I only hope that the new Defender also has a completely dysfunctional heater in order to maintain the tradition.
Post #800858 5th Nov 2019 10:50am
rallysteve
Rolling with laughter very true, i fitted a rubber fin onto the rear of the intake on my Series 3 and it made a huge difference to the airflow at speed.
Post #800861 5th Nov 2019 11:04am
