Home > Technical > Nokian Winter tyres non studded - worth a try
jst
i thought about this alot last year and having gained a vehicle this year thought again long and hard (which didnt take me long....) and have just purchased a set of Nokian LT2s. local tyre shop couldnt get within £50 of online per tyre so online it was, arrived today, pick up rims for them Monday and will see how they fair!
this is the first year i have moved away from BFG ATs for the winter. that vehicle is currently shod with BFG MTs and i dont rate them on the colder icy roads and compacted snow we get around here so Nokians it is!
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800227 31st Oct 2019 7:00pm
They look good
Post #800244 31st Oct 2019 8:04pm
Sulisuli
Be interesting to see how these perform James Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #800245 31st Oct 2019 8:04pm
jst
Will keep you posted. the roads around here are not great come winter and the benefit of better compound for the cold wont hurt either. at least it will stop better than the ATs and directional stability should be better. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800255 31st Oct 2019 9:00pm
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
I’ve got 8+ years on a set of those. Half the time I failed to take them off during the summer!
Post #800269 31st Oct 2019 11:27pm
jst
I have read they wear well Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800273 1st Nov 2019 12:03am
ericvv
Good choice, you won’t regret it. I ran the LT for 7 winters, now the LT2 are on and will enter their 3rd winter. Main reason I replaced the first LT set was that I also bought a new set of HD Wolfs, the genuine gloss black version. I was still on 80% with those LT, but thought after 7 years the rubber might have hardened a bit, and living a bit higher up above the lake now, better to play it optimally safe. The LT2 are also quieter than the LT, actually no difference with my summer GG TR. My tire center initially installed the new LT2 on the Wolfs using standard lead weights for balancing. In order to not damage the paint on these steel rims, now before each winter they are rebalanced leaving those original standard weights on, but adding glue on weights which each time can easily be removed again without paint damage. Sofar that works very well, wheels were just rebalanced and they never had to use more than 40 gram new glue on weights on a wheel.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #800274 1st Nov 2019 4:37am
jst
cheers Eric. i am going to stick these on an old set of boosts and am not too worried about the rims for balancing wise so will just see how they go! The rims are winter set anyway so expecting some damage from corrosion. Bet we have a really mild winter now. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800279 1st Nov 2019 6:57am
Mdm
we ran them on a bmw and they were great .we did some testing on corsa and ran 3 different brands and all were very good and all did 3 yrs of fair mileage .
cheaper ones wear rate was much higher then the nokians which did a 4 year and still had 3-4mm of tread at that age.
i rate them as good as the Dunlop winters we ran before on various bmws at work.
Post #800297 1st Nov 2019 9:16am
90 Dreamer
silly question but whats the "%" marking on the tyre tread?
Post #800301 1st Nov 2019 9:47am
grafty99
Remaining tread depth.
As the tyres wear the percentages dissappear Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #800303 1st Nov 2019 9:52am
90 Dreamer
cheers, presumed that was the case but wasn't sure by the pix..........
Post #800306 1st Nov 2019 10:35am
SteveG
2005 Defender 90 Td5 CSW Belize Green
You’ll also appreciate how good they are in the wet James, especially on dual carriage ways/motorways when you hit a bit of surface water at speed.
cheers, Steve
Post #800590 3rd Nov 2019 3:11pm
jst
well its certainly wet to try them! pick up the rims tomorrow then straight to the tyre machine! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #800603 3rd Nov 2019 5:05pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I’ve been looking at the cooper discoverer at3 4s anyone tried these? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #800610 3rd Nov 2019 5:25pm
