![]() | Home > Tdi > Will a Td5 Transfer Case bolt straight into a 300Tdi? |
RobM Member Since: 06 Jul 2015 Location: Brisbane Posts: 55 ![]() ![]() ![]() |
Guys...
I'm looking to buy a TC out of a Td5 Defender but I'm a little bit unsure if it will simply bolt straight in without any mods. I know the Td5's have a electronic speedo whereas the 300Tdi's don't - will this be an issue? Rob Cheers..... Rob 1995 Defender Tdi 110Wgn 2010 Defender PUMA 110Wgn TRIPS: Meanderingdownunder WikiLoc Trips |
Td5's have a electronic speedo whereas the 300Tdi's don't - will this be an issue? No as Speedometer Transducer can be removed
then removing the transfer cases just make a note of there bolts are from as not all same length ![]() ![]() ![]() or swap over the speedo on the dash to an electronic version and add the wiring and plug http://www.retroanaconda.com/landrover/200...tdi300tdi/ Last edited by dorsetsmith on 28th Oct 2019 10:52am. Edited 1 time in total |
This sounds interesting... My speedo is terribly inaccurate so I like to know more about this mod ?? Cheers..... Rob 1995 Defender Tdi 110Wgn 2010 Defender PUMA 110Wgn TRIPS: Meanderingdownunder WikiLoc Trips |
Thanks for the link -- reading it now ![]() Rob 1995 Defender Tdi 110Wgn 2010 Defender PUMA 110Wgn TRIPS: Meanderingdownunder WikiLoc Trips |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 363 ![]() ![]() ![]() |
My 300Tdi came out standard with the electronic speedo. Very nice.
