Home > In Car Electronics > Econoseal Connectors - Disassembly
discomog
I'm wanting to re-route a cable which is fitted with a female Econoseal connector. In order to pass the cable through a small hole I need to remove the Econoseal connector. Can someone tell me how to remove the connector and if so can I reuse it or do I have to cut it off and fit a new one? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #797845 12th Oct 2019 1:13pm
Try something like this:
https://www.polevolt.co.uk/acatalog/Termin...-TT99.html
There are cheaper out there, but I have found that these two tools have served me well over many years.
Post #797855 12th Oct 2019 3:43pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
I have the same tools as above, and they are good for the money but can be hit and miss sometimes. I have a selection of dental tools at my disposal, and they are some of the handiest yet oddest pieces of kit I have in the toolbox.
The econoseals can be a bit frustrating- can’t remember which side is which (female / male) but if you remove the yellow cover plates you will see slots above the terminals, using a flat thin blade type removal tool insert this to push the tang down and then remove the terminal. You may need to give it some vertical pressure to move the tang if it’s not playing game, but persevere and you’ll get there.
Give the terminals an inspection when they are out, i had corrosion on my bulkhead connectors which led me to reterminate the lot.
On reassembly give the seal some lubrication on insertion to help it slip on in (all innuendo’s on purpose).
Enjoy.
Post #797861 12th Oct 2019 4:07pm
discomog
I've managed to disassemble the connector following advice from Zippo - many thanks. I also did it without any specialist tools but thanks all the same Supacat. Defender 90XS SW
Morgan Plus 8
Post #797939 13th Oct 2019 11:27am
zippo87
Post #797942 13th Oct 2019 12:31pm
AlexSmith
Brazil 2004 Defender 110 300 Tdi SW Alpine White
Same here! Had a problem on the rear flashlights today and had to remove the connector for cleaning. It took a long time and a lot of patience, but in the end they came out. Thanks! 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray
2002-2005: Defender 90 CSW 300 Tdi Dark Green
Post #986822 26th Mar 2023 1:45am
rallysteve
Have got a few different terminal removal tools/kits but for econoseal I always just default to using a cheap scribe tool from toolstation:
https://www.toolstation.com/engineers-scriber/p76054
Post #986828 26th Mar 2023 7:59am
PaulMc
A safety pin works well on Econoseals, Multilocks, HM series, and many other types, where the terminals are located by a 'tang'
. Paul.
Post #986836 26th Mar 2023 8:46am
AlexSmith
Steve
Makes sense! I ended up getting it apart by using a small piece of rigid wire, which is basically the same as this tool. Smile 2020: Defender 110 SW 300 Tdi 2004 Alpine White
Post #986917 26th Mar 2023 6:26pm
