Home > In Car Electronics > Extra 12v socket installation issue
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
As title suggests I've wired a secondary socket direct to battery with inline fuse and negative to a good earth on body. The cables are showing 12.7v the same as the standard socket on dash as is the secondary socket. Satnav plug illuminates to show it is live but the satnav is dead. Plugging same power cable into standard socket the satnav powers up. I'm stumped. Any suggestions please. Confused
Post #795119 25th Sep 2019 7:47pm
The obvious thought is that the wires are reversed. You'd still get 12v but the sat nav probably needs the polarity to be correct. Darren
Post #795122 25th Sep 2019 7:59pm
ginjez
Hi Darren, polariity is correct according to volt meter.
Post #795123 25th Sep 2019 8:09pm
Dunno then. Duff socket contacts, maybe? Darren
Post #795133 25th Sep 2019 8:49pm
Lefty loosey
Wales 2002 Defender 110 Td5 CSW Caledonian Blue
Bad connection somewhere when the circuit is under load the voltage drops. I know the satnav will only be a small load but might drop it enough to not power the satnav and only the led.
Post #795137 25th Sep 2019 9:01pm
ginjez
I'll check earth tomorrow.
Welcome to forum btw Thumbs Up
Post #795139 25th Sep 2019 9:04pm
Pilgrimmick
12.7v is that with the engine running? If so it is low, wants to be about 14v 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #795158 26th Sep 2019 7:29am
ginjez
Checked tonight and you are correct Bow down
Post #795261 26th Sep 2019 7:03pm
