Home > Maintenance & Modifications > Britpart extended wheel arches |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
Hi
I'm running with 30mm spacers and 265 tyres. As a result I get a lot of muck spraying up the side of my car. Can't fit the Dirt D-fender that MUD supply as I have tree sliders fitted. I've seen these beasties from Britpart... https://www.britpart.com/parts/exterior-pr...its/da1978 Anyone have any experience of them? I'm tempted as they look OEM, should have the same OEM flexibility and, at 30mm wider than OEM, should put me back to where I was (muck wise ) before adding the spacers. There seem to be loads of different prices out there as well so I'm a bit uncertain as to what would actually be supplied. For example, Britpart supply as front/rear pairs at (about) £92 but I found these as well https://www.lrparts.net/lrc1418-set-of-fou...-pair.html That seems sensible as a full set but why is cutting needed? I assumed you'd just unclip the originals and clip in the replacements? Confused, as seems to be the norm these days Tony |
19th Sep 2019 1:03pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
The reason you need to cut is in the installation instructions
https://www.lrparts.net/mwdownloads/download/link/id/3/ That's a bit . Would it have hurt them so much just to make a complete arch.... ! |
19th Sep 2019 3:52pm |
Have you considered the Gwyn Lewis mud flap extenders? They push the flaps further outboard to solve exactly this problem. Darren
19th Sep 2019 8:25pm |
Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89 |
Click image to enlarge I like em, inner arch needs cutting out, also have the gwyn lewis mudflap brackets |
19th Sep 2019 9:41pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Click image to enlarge I was really unsure, Mrs G said she preferred original, so I switched back. |
20th Sep 2019 6:42am |
Oops, that’s before.
After. Click image to enlarge |
20th Sep 2019 6:44am |
I agree, looks better with the standard ones!
I have the gwyn lewis mud flap extenders mentioned. They are brilliant, no muck on the sides with sticky outey tyres. |
20th Sep 2019 7:34am |
Thanks for the replies. I'll have a bash at the mud flap extenders and see how it goes. Not sure about the Britpart arches from the pics.
Tony |
20th Sep 2019 12:12pm |
