Home > Puma (Tdci) > connector subwoofer
browny
connector subwoofer
Hi all
Got hold of an original sub woofer for the Defender. As my 2007 has the right Alpine radio, but I have no cable/plug to connect to the sub woofer. Would any one know the part number of the cable/plug between radio and subwoofer by any chance. Or someone got the matching plug and the cabling chart?
Thx
browny
Post #793585 17th Sep 2019 12:47pm
Martin
Site Admin
There's no separate loom available for the subwoofer end, only bits of adapter harnesses at the radio end.
I can supply a plug and pins for £7 plus £3 UK post (it's lumpy) - I've done a retrofit on my 2014 90 XS by building a custom retrofit loom.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #793590 17th Sep 2019 1:01pm
P055um
United Kingdom 2009 Defender 110 Puma 2.4 USW Keswick Green
Hi - I had the same problem. Called Alpine and explained the situation and they have a wiring kit for the standard SWE1200 which will work with the special version developed for the Puma. It is not cheap (about £30 from memory) and I believe that the part number is PA015000A034.
You will need to remove the amp from the unit and remove the lead to the power supply and replace with the Alpine wiring kit. This will give you all the connections for the head unit.
Used it on my retrofit and it works fine.
Hope this helps.
Post #794407 21st Sep 2019 11:02pm
P055um
Just checked - the part number for the power cord is 01E44813S01. Price was £36 inc shipping etc. There is a guy on ebay selling one for slightly more.
Should have mentioned that the RCA connectors are fairly short and I purchased a 3m extension (male to male fittings) to link up to the head unit.
However, getting the plug and pins from Martin would be a much cheaper option!
Post #794435 22nd Sep 2019 7:35am
Matt110
In the OE install where do the RCA cables route?
Post #794490 22nd Sep 2019 1:14pm
mcma1
Hope this helps.
Is there much difference between the LR one and the SWE1200? Been trying to find a used factory one for ages now. One on ebay at the minute but looks like its been kicked down the road! Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #794497 22nd Sep 2019 2:27pm
P055um
The LR one has the amp integrated and therefore is a bit deeper than SWE which comes with it separately. Also, the Alpine logo is upside down if fitting on the back of the cubby box.
Post #794498 22nd Sep 2019 2:32pm
mcma1
can it not just be fitted the other way round? Confused Andy
2014 Corris 110 SW
LS3 V8 build...
Post #794499 22nd Sep 2019 2:43pm
P055um
I am sure that it would work just fine. It is just that the speaker aperture would be facing upwards. Otherwise no problem. Or just live with the logo upside down...
Post #794514 22nd Sep 2019 4:06pm
