Home > Maintenance & Modifications > Webasto cabin heater positioning
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
Hi All
I’m finally getting around to getting a Webasto fitted (professionally). They’ve suggested underneath the second row (I’ve a 110 CSW) as this location is ideal for best warm air distribution around the entire car.
This sounds sensible, but I’m just wondering about cargo space infringement on the occasions when I push the second row of seats forward to fit a little more in.
I’ve seen and suggested the Mud box which goes underneath the cubby box, but they’ve (rightly) noted the additional height on what is already a raised cubby box.
Any thoughts gratefully received?
Thanks
Post #793345 16th Sep 2019 4:19pm
walfy
I have my webasto fitted under the 60 portion of the 60/40 split. I run some ducting up behind the seat and up the side of the dog guard. It then points slightly forwards. Heats the cabin up in a matter of minutes 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #793381 16th Sep 2019 6:41pm
excossack
I am doing mine at the mo, and I have put the heater under the rear (2nd row) seat towards the door. Warm air will exit under the middle seat (mine are 3 separate seats). 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #793407 16th Sep 2019 8:42pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Thought about fitting one to mine. I would try under the 40% seat so you can fold down the 60% when you need more space.
Post #793408 16th Sep 2019 8:50pm
Fellrunner
Thanks All. Really helpful. Looking at the 2nd row placement again, positioning there will infringe very little as it can be placed very close to the pivot point for the seats. All it needs is a protective cover/box for when loads are being pushed in from the back door along the floor perhaps.
Looking forward to being warm this winter!
Post #793471 17th Sep 2019 7:32am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I’d fit it under the cubby box. Simply make a lower cubby.
Post #793478 17th Sep 2019 8:08am
wyvern
Having had one fitted under the 2nd row and under the cubby - I found the cubby was the better place to fit it.
Under the 2nd row was a pain when you wanted to stow things in the back with the seats folded and the air intake/hot air out let used to become blocked with coats and stuff if you were not careful..
Under the cubby was a simple fit with the ‘Nakatanenga’ under-cubby box and the hot air outlet in a good location to heat the cabin.
Links to battery and fuel were simple as was the positioning of the fuel line, exhaust and external air intake.
Yes it does make the cubby a little higher but it only took about a week to get used to the new position.
However, with some tweaking you may even be able to make it fit inside the cubby box with a false floor.
Fitting the heater under the cubby - work in progress ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #793504 17th Sep 2019 9:16am
jst
Mines under the 60 of the rear seat. Seats folds forward no problem and it's no higher than the seat brackets. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #793713 17th Sep 2019 10:39pm
Gilloverland
I fitted mine (chinese copy) in the mud heater locker with the cubby on top.
As has been said, really easy to sort the intake / exhaust / fuel line etc:
https://www.defender2.net/forum/topic66584.html
Post #794050 19th Sep 2019 8:23pm
west4x4
On my old 110 it was under rear seats drivers side. Blew warm air around seat back making your lower back lovely and toasty. I never folded the seats
Post #794082 19th Sep 2019 9:19pm
90 Dreamer
Is the Webasto heater electric or diesel??
Post #794083 19th Sep 2019 9:22pm
jst
electric operated, diesel burner. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #794096 19th Sep 2019 9:38pm
90 Dreamer
Cheers, has anyone ever found a pure electric heater??
For a different vehicle application and diesel fuel / water plumbing isn't feasible.....
Post #794107 19th Sep 2019 9:54pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
No experience of them myself but these aircon units with heaters are very well regarded.
http://www.hvac-aircon.com.
http://www.hvac-aircon.com/hvac-unit/
Post #794109 19th Sep 2019 10:01pm
