Home > Wheels & Tyres > 16" tyre pressure variations
90 Dreamer
Just looking for some ideas about ideal pressures in various situations - have seen as little as 30psi and towards 50psi depending on road use and towing, etc........
Not done loads of miles but have tried early 30's all round and then inflated rears to 48psi to tow, ending up using this pressure for a shot commute until i could alter them and noticed it was far more rigid and very keen to activate the traction light in this state........
If you did a little light green laning would you drop them further??
If it matters its a late model Puma 2.2 H/T 90
Post #793073 14th Sep 2019 9:33pm
Grouse
28 front and 35 rear - 110 with HD suspension and average load - if fully laden 48 rear
28 Front and 48 rear is std for MOD 110
Post #793078 14th Sep 2019 10:40pm
Naks
One of my long-time overlanding friends showed me the correct way determine your tyre pressures:
Every tyre has a max load, max pressure, and max speed rating.
Load your car and weigh it on each axle.
Then work out the pressure from there.
You can then adjust as you need for different loads, etc.
For gravel travel, drop by half, or 1,8 bar.
For off-roading, drop to 1.4-1.6 bar.
For sand, drop to 1.0 bar, 0.8 bar if very soft sand. --
Post #793083 15th Sep 2019 6:18am
Co1
I have a 90 HT puma, and unladen I go with 30psi all round. Seems comfortable enough to me and no traction issues.
Post #793084 15th Sep 2019 6:31am
landy andy
32 all corners. If serious mud then drop to 12
Post #793090 15th Sep 2019 7:13am
90 Dreamer
And if towing around 48psi for the rear with fronts more 30's is fine??
Post #793114 15th Sep 2019 9:00am
HardCharger
I just follow the manual and the label on the door jamb, 30 psi front, 48 psi rear. I add 2 to 4 psi if I've been running for a while when checking the pressures.
One of my friends suggested that I lower the pressures a bit as the ride was, according to him, a bit on the bouncy side. This is when I ran the Cooper STMaxx that I got as new old stock so the rubber might have hardened already. When I recently switched to newly manufactured Pirelli Scorpion MTs, even with the 30 - 48 pressures, the ride is very civil.
There are proponents to the 4 psi rule which involves a lot of measuring to determine pressures as they will work for you and your set up. But once you find out the appropriate pressures for you, it'll be pretty spot on to ensure longer wear intervals for your tires, a good ride, and optimal traction provided. Once I get better kit, I'll probably do this again as it did wonders for my H*L*x back in the day.
Post #793269 16th Sep 2019 2:30am
