Home > Stolen > Extra Security
Grenadier
Extra Security
Having just seen that Neon1991's Defender has unfortunately been half-inched from behind gates and with a tracker disabled, has anyone considered using a pressure pad under the wheel to act as an alarm? Reverse engineered so that when 'set' it triggers only when the rear wheel rolls 'off' the pad rather than on it? Small enough as to be invisible under the wheel. Wireless and tied to phone/doorbell/outdoor lights? Maybe even a small, hidden high-piercing alarm box hidden elsewhere in the vehicle, such as rear wheel arch etc?
https://www.ultrasecuredirect.com/floor-pressure-mat-alarms-c452
I'm not a techy guy, but surely this could be made by someone? If the baddies have to disable the battery to kill the main alarm/tracker, then they won't be able to drive it immediately and will either have to push/tow it off the driveway as quietly (ergo slowly) as possible. An entirely unexpected bright light, a piercing alarm, and a notified owner in the house would surely make them scarper?
No doubt a boffin will tell me this is impossible, but just a thought. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #792484 12th Sep 2019 1:13pm
bear100
umm sounds interesting Idea watching this one Thumbs Up
layers of security is a good approach, more layers the better Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #792485 12th Sep 2019 1:29pm
JOW240725
My father used to have a pressure pad alarm on the staircase to be warned when the dog was trying to sneak upstairs! Should be relatively simple with a few bits from Maplin!
However depending on vehicle location, a simple blue flashing beacon and alarm on a PIR sensor to warn of any movement would also work well? James
Instagram @suffolk_rovers
Post #792498 12th Sep 2019 2:43pm
discomog
Good idea. There are a number of pressure mat sensors available for the elderly and infirm that alarm when a person stands up from a chair or attempts to get out of bed. Similar principle so shouldn't be too difficult to source something. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #792500 12th Sep 2019 2:49pm
Grenadier
The other option, if something under the wheel is too complicated, is a pad in the driver’s seat, separate hidden battery, piercing alarm in cabin. I’m assuming almost all tea-leaves will sit in the seat at some point to steer/fiddle with writing etc? You could even put in a vibrator (ahem Whistle ). Pure shock and awe. Least excepted, louder than expected, and no ability to source the alarm or turn it off as it is neither standard nor wired to the primary battery.... Thumbs Up Monsieur Le Grenadier
Post #792504 12th Sep 2019 3:20pm
Stacey007
My friend had his Van broken into (no damage) and all his tools taken...
He now has a PIR sensor (they are wireless) in the van that links to the house alarm. Works a treat in a Van as the back is dark.
Maybe a utility this would be ok also?
Post #792508 12th Sep 2019 3:26pm
rallysteve
I am afraid Maplin has long gone! 02' 110 TD5 Double Cab Rebuild Thread
Post #792612 12th Sep 2019 7:44pm
Sulisuli
Bit like the defender after yesterday Shocked 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #792614 12th Sep 2019 7:47pm
OsloBlue
I've been thinking about this for a long time, i was gong to get someone to build me a device that would send me an SMS message whenever the ignition was engaged in position 1 2 or 3. but im not good at electrical design and wouldn't know where to start or even where to build one.
another thing i was thinking about a wireless baby monitor as mad as that sounds.
One of the irish chaps on site kept having his bikes nicked until he hooked his bike up the main power in the house.
https://www.johnlewis.com/bt-video-baby-mo...lsrc=aw.ds I'm on IG: https://www.instagram.com/osloblue42/
Post #792648 12th Sep 2019 9:36pm
AMBxx
those cheapo amazon trackers have the facility to send a text every time you turn on the ignition. Can be set to the interior lights too.
Post #792671 13th Sep 2019 5:59am
Procta
A few people have started to ask questions about tracked defenders been hit and the device removed . So either someone who is installing these on defenders are giving the game away. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #792829 13th Sep 2019 3:44pm
