Home > Puma (Tdci) > HANDBRAKE QUICKFIX |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 |
The adjustment is on the hand brake drum and cable. Normally just start with adjusting the pads at the drum.This is done without removing the drum as there is an external adjuster. If still too slack then the cable can be adjusted.
A search on the site should give you more information on how to do it. |
31st Aug 2019 10:33am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello bunnyman
Technically easy to do. Locate the adjustment bolt on the lower section of the handbrake drum, this is a forward facing Hex bolt... but be carful on first moving it... mine was very stiff at its first adjustment (25K mileage)… I like the hand brake to come on early on lift and 'secure' at 3-4 clicks, anyway, my adjustment mechanism wasn't happy on tightening up and then backing off until desired (correct) setting reached, so it was swapped out for a new unit... I just move it fractionally at each service, or when occasionally underneath Click image to enlarge Click image to enlarge Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
31st Aug 2019 10:49am |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 123 |
Thank you for your help, all done
Regards Bunny |
31st Aug 2019 12:31pm |
