Home > In Car Electronics > Broken heated rear window connections |
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 |
Is there any way to repair broken connections on the rear heated window - looks like the 2 soldered joints on the bottom right of the window have broken off . Is there any suggested ways to repair this.
Local garage & dealer both say its a new window Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
27th Aug 2019 12:02pm |
caterham6 Member Since: 18 May 2014 Location: Manchester Posts: 47 |
Easy wire out black cable with crimp conn I did mine as for the solder use a soldering iron,Run cable on edge of screen rubber its easy only for brake light.
27th Aug 2019 7:10pm |
