![]() | Home > Wheels & Tyres > Novice - Change Boost alloys to Steel modular |
Dagonet Member Since: 15 May 2019 Location: London Posts: 10 ![]() ![]() ![]() |
Hi Folks,
I want to switch a set of Boost alloys for these steel modular wheels. https://www.4x4tyres.co.uk/16-tuff-torque-...6508tgbmod Do I need to change the hubs? What sort of nuts do I need to get? What are the pitfalls? Thanks in advance wise ones. |
Thanks chap.
Good choice, as above just need a set of steel wheel nuts.
Being ET0 don't forget to adjust your steering stops to improve your turning circle. ![]() Oh and don't forget to post before and after photos ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Thought you could use alloy wheel nuts on steel rims, but not steel nuts on alloy wheels? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
You can use alloy nuts with steels (for example to use a steel spare in place of an alloy), but they look a bit odd and sticky-out.
Right, thought so, agreed, though
Thanks for all the advice folks. I'll be sure to post pics when the transformation is complete.
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
These nuts are very good.
![]() http://www.wrington.co.uk/land%20rover%20s...0nuts.html |
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 ![]() ![]() |
Good choice of rims. IMHO steel modular rims are the dogs dangly bits for a Defender!!
![]() Click image to enlarge ![]() Click image to enlarge |
