Home > Maintenance & Modifications > Defender door swap questions
Djcla
Hi
My td5 doors are in bad shape at bottom and I was thinking when I save up I'd just buy two puma doors on eBay or similar with electric windows, central locking etc. Is it a straight swap as my TD5 car has alarm, central locking and electric windows currently? Also will I need new door cards¿
Post #787533 18th Aug 2019 7:08pm
They are physically a straight swap. If you manage to get a pair with the same features as your existing then the wiring will match up, too. I think the door cards are different, although they look the same externally. Darren
Post #787540 18th Aug 2019 7:35pm
NickMc
Yes door card is a different profile on the curve.
Post #787557 19th Aug 2019 12:52am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Weren’t the late Td5 doors steel and similar to the Puma versions, I.e. stronger and better made?
Post #787582 19th Aug 2019 9:14am
Martin
Site Admin
Yes late Td5s have "Puma" doors  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #787584 19th Aug 2019 9:25am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Re: Defender door swap questions
Be aware that it is entirely possible that 2nd-hand doors could come from stolen or de-doored Defenders. Even if we're not direct victims (yet) that is something that affects us all indirectly though insurance costs. So try to determine the provenance of any 2nd-hand panels before purchase.
The SP4x4 doors are extremely good quality and are available in various styles: https://www.sp-4x4.com/category_s/242.htm
Buying new means that you can be certain that you're not fueling the ongoing Defender related crime epidemic.
Post #787596 19th Aug 2019 10:25am
NickMc
SP doors are not good quality the rear ones especially Whistle
Post #787729 19th Aug 2019 6:06pm
Intercept
I can't comment on the rear doors, but the SP4x4 galvanised frame, steel skinned front & 2nd row doors I fitted to my DC a couple of years back were superb quality and have been trouble free since.
Post #787856 20th Aug 2019 10:28am
Djcla
So I could buy them and just transfer everything across from mine?
Post #787857 20th Aug 2019 10:45am
Intercept
That's exactly what I did in 2017. You'll need a sprayshop that's familiar with painting galvanised steel if you go for that option. The photo shows my pre-spray prep i.e. re-drilling holes and re-cutting threads partially blocked with zinc.
Post #787866 20th Aug 2019 11:36am
