Home > Maintenance & Modifications > LED headlight installation question
El Rey
Australia
I'm going to try these LED headlights:
https://www.stedi.com.au/stedi-7-inch-carb...ight.html#
As far as I can see there is only the three-way connector going into the existing headlight,
but there is an extra red wire on the back of the LED headlight (see picture attached).
Anybody know what that might be for, and if it's redundant, what to do with it?
I'm an electrical n00b, so even the most basic advice appreciated.
Cheers in advance
Post #785844 9th Aug 2019 11:38am
El Rey
Australia
On the product page it says 'The integrated optional halo DRL can be wired to ignition or to a dedicated switch to illuminate to offer day-time safety.'
Would that be what the red wire is?
Post #785845 9th Aug 2019 11:40am
Martin
Site Admin
The original 3-pin has no facility to connect a side light or DRL or yes I would imagine that 12V on that red wire illuminates the DRL.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #785847 9th Aug 2019 11:51am
El Rey
Australia
Sweet, cheers for that. There goes my plan to install them myself - will look for an auto sparky.
Post #785848 9th Aug 2019 12:03pm
Martin
Site Admin
Don't use the DRL Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #785849 9th Aug 2019 12:04pm
El Rey
Australia
Hah! Yes that's an option I guess.
Don't fancy a loose wire hanging around in there for some reason.
Maybe a touch of OCD.
Post #785850 9th Aug 2019 12:07pm
A 1pole superseal connector capped would be suitable.
You could also take a feed from the sidelights givin you a DRL with sidelights only,
Then you have a sidelights DRL, Dipped and Main.
Ideally you sidelight should be LED as well though and you can get a piggyback loom to plug straight in lie Brendan at 4x4 Overlander has. Thumbs Up No Guts, No Glory.
Post #785877 9th Aug 2019 1:54pm
El Rey
Australia
Gracias - I’ll look up his Defender to see what you mean.
Post #785885 9th Aug 2019 2:20pm
El Rey
Australia
FYI I am meeting up with an auto sparky on Monday morning to help put all the lights in.
Will discuss the suggested DRL solution with him on the day, and post an update once it's done.
Post #787138 16th Aug 2019 8:16am
El Rey
Australia
DRLs connected to the side lights - look good!
The smoked lights look good all round too.
Cheers again for the advice on here.
Post #787576 19th Aug 2019 8:45am
Caterham
looking fantastic. Thumbs Up
Post #787644 19th Aug 2019 2:24pm
Sulisuli
Looks great. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #787650 19th Aug 2019 2:43pm
El Rey
Australia
A short clip of the dynamic side indicators too:
Post #787666 19th Aug 2019 3:22pm
Sulisuli
I like those Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #787674 19th Aug 2019 3:42pm
