![]() | Home > My Defender > 100,000 miles |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Nice one. Well done
![]() At my current usage I should get there in 2048 ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
![]() so far as I'm aware the only way a defender will reach 100k miles with not may bills is on the back of a trailer ![]() congrats. 100k is without a doubt a mile stone, even if the motor does feel likes it's run in and going a treat ![]() good old 2.4 ![]() |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 685 ![]() ![]() ![]() |
It’s been dealer serviced (Hillendale, now Farnel Nelson) every year.
Two new EGRVs under the warranty New front half shafts Twice changed rear half shafts RH swivel changed Brake pads and front discs On 4th set of tyres (brand new ones on at moment so each set have each done 33k) Since it is worked hard as my works vehicle as well carrying our demountable camper on holidays and towing a trailer I think it has done well. Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
2 egrs !
I'm still on the original at 101k miles. ![]() in other areas I've probably replaced quite a bit more than yourself. ![]() but the engine is running a dream at the moment and I hope it continues to do so. ![]() welcome to the 100k club ![]() |
Is it still on the original clutch and adaptor shaft?
![]() I sincerely hope not!!. I'd happily swap a couple of egr for the number of adapter shafts and clutches I've had. |
Engine, transmission, clutch etc have never needed any attention. 130 Puma HCPU with an Artica 240LR Demountable Camper
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
^ that’s quite a result
![]() 2008 SVX 90 2000 XS TD5 90 |
WHAT THE HELL ! ??
surely you've had to replace the adapter shaft or the clutch or do you mean you've not had cos you've had replace the whole lot and not just bits? if not I'd love to know what the secret is..... are you sure it's not a Td5? |
just noticed the speed ![]() ![]() |
Caterham he did that mileage on 2 tanks of fuel bud, think you might have some competition rolllaugh:
I’ve never had to replace a clutch or gearbox on any vehicle I’ve owned and I take most well past 100k. I’ve always been firm but fair with my left leg.
If you’ve ever driven on A15 into Europoort in rush hour you would know that 50mph is an achievement. 130 Puma HCPU with an Artica 240LR Demountable Camper |
In fairness my SVX had done 108000 miles when I sold it and likewise I had nothing done to it at all just like RFT, sometimes you just get lucky
![]() I guess I didn't get lucky. good for you two. ![]() |
