Home > Puma (Tdci) > increased engine and gearbox noise after clutch/lt230 swap
Page 2 of 3 <123>
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Is the increase in noise because the exhaust has not been correctly refitted when they have take the central part out to drop the box. Have they forced something that has misaligned the exhaust to manifold? Bit of a long shot but worth checking.
Post #786076 10th Aug 2019 11:21am
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
problem solved! the thing that tipped it over the edge for me is the missus was in the car when we took the trailer off to the tip and she said that it sounded a hell of a lot noisier than usual.... her words were "did they forget to put the sound deadening back in?"
so i stripped out the interior piece by piece and found three issues;
1) seal around the plastic transmission tunnel was not fitted right - the rear half of it was just hanging there which gave me a 1/2" gap all the way aroudn the back of the gear shifters... no wonder it was noisy.
2) the plastic cover over the transfer case linkage was out of place and stuck between the shifter and the transmission tunnel
3) the cover over the transfer case (under the cubby) was not sitting flush.
I sorted out 1 and 2, then for 3) I added some foam draft excluder strip on the edges of the panel and bent it back down to get to seal.
Started it up and low and behold - silence (well in defender terms) was re-instated. As the interior was so stipped down (seats out, seat box vinyl out etc) I thought as good as time as any and I used the last of the 2mm silent coat and 9mm dodomat to coat the entire seat box and foot wells. I put the dodo mat inside the seatbox where possible to let the vinyl matting sit OK and also not to foul the doors when they are shut.
I cant believe how much difference that made! I had already done the entire rear floor, hardtop sides and the entire roof with the silent coat and dodomat but did nto expect the footwells and seatbox to make so much difference.
spotted some wear on the nylon cage of the shifter too.... see link... everything looked OK and unworn, but might try a new cage 1st as its a cheap option.
Mike
[/img]
Post #786405 11th Aug 2019 11:01pm
That is shocking workmanship by the garage and I would certainly never take any business there in the future. Shocked
Post #786426 12th Aug 2019 8:45am
LR90XS2011
LR90XS2011 wrote:
you state you noticed it was noisier as soon as you started it, if its noisier in neutral when stationary then its nothing to do with the transfer box or adaptor shaft as they are doing nothing and are stationary, its unlikely to be the gearbox as not much is happening in there so its probably either the clutch is noisy for some reason (unlikely) so probably a panel, floor seal or sound proofing issue, or there may be something loose underneath like the exhaust
feels good to diagnose things from the settee, glad its sorted, DEFENDER 90 TDCI XS,
Post #786642 13th Aug 2019 6:05pm
Mike_E
👍 thanks for the heads up.
Post #786651 13th Aug 2019 7:45pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Excellent work.
I lost my knife sharpener yesterday. Do you know where it is?
Post #786653 13th Aug 2019 8:01pm
LR90XS2011
LOL
Not having much luck with the LOTTO DEFENDER 90 TDCI XS,
Post #786675 13th Aug 2019 9:04pm
flyingfab
France 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
Hi Mike,
I would still be very concerned about the gearbox's top up they did. Overfilling the MT-82 is not an uncommon mistake. Considering your garage's work on the covers and what they told you, I would take their incompetence for granted and assume they actually overfilled the gearbox. Adding 1,5l sounds astonishing.
If overfilled, it will eventually cause a shaft seal failure, due to overpressure when the gearbox is warm. If it was my Defender, I wouldn't hesitate : I would go for oil replacement asap and refill with the proper amount (2,2l and nothing more).
It might be for nothing... but I do believe it's worth the shot. It will definitely be much cheaper than replacing the seal when it fails Wink
Cheers,
Fabien
Post #786883 14th Aug 2019 11:46pm
Mike_E
Agreed. I am 100% sute its overfilled.
I was waiting for the magnetic drain plug which just just avarived as did 3ltrs if the correct ford spec oil for the mt82. I'll be doing it tomorrow!
Thanks
Post #786904 15th Aug 2019 8:27am
Mike_E
Dropped the oil out of the gearbox... 3.7ltrs.
Ie 2.2 + the 1.5 they added.. will speak with garage on Monday.
A little worrying is whilst under there I thought I'd do the diffs and also change the transfer case oil. I always do this after an engine rebuild or similar after a few hundred miles to get rid of any swarf. Diffs went fine, no issues. Dropped the oil out of the transfer case and it looked filthy. Its only done 300miles!
Will email the photos to Ashcroft tomorrow to see what they think.
Mik
Post #787392 17th Aug 2019 8:58pm
Mike_E
Post #787394 17th Aug 2019 9:12pm
Zed
That's outrageous. I'd be livid.
Post #787400 17th Aug 2019 9:30pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Yup, likewise. Furious. Keep you cool but be firm. This could have seriously shortened the life of your box, seals etc.
Post #787402 17th Aug 2019 9:32pm
Zed
Also by the sounds of it they over fill every Defender. Goodness knows how many will be affected.
Post #787404 17th Aug 2019 9:35pm
Mike_E
Those photos are the oil from the recon lt230 at 300 miles...
Post #787415 17th Aug 2019 11:07pm
Page 2 of 3 <123>
