Home > Puma (Tdci) > Success with creaking
Roba71
New Zealand 2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Last week i started to hear a plastic like creaking in and around the drivers footwell.
It progressively got a lot louder, to the point the radio couldn't drown it out.
After laying on the ground and checking all the nuts and bolts i could reach. I found one 10mm headed nut really loose, its under the hand brake under the mat. Tightened it up and no creaking.
Not so much luck with what sounds like a coin rolling from side to side directly inline with the head of the gearknob, its so annoying every time you turn a corner something rolls just like a coin or nut.
I removed the dash/console nothing!! And the gearlever to check the weights on the end with no luck, and checked and lubed the bonnet hinges
Any other suggestions please ?
Post #783351 27th Jul 2019 3:38am
