Home > Off Topic > Supplier of end of life taps |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
If they are the same as these
Then http://www.vitra.nationwide-bathrooms.co.u...-taps.html have them n stock you may be able to bend their ear to sell you one For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
10th Jul 2019 3:43pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
Drill through back of tap head and either tap a thread then use a grub screw or drill tap head and spindle, then insert pin through both would be alternative options.
10th Jul 2019 8:41pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Them the ones - thanks. I have emailed them 1999 Defender TD5 110
10th Jul 2019 9:09pm |
That is a plan I have thought of, and may come to that if I can't get tap handles. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
10th Jul 2019 9:10pm |
Called the people nationwide bathrooms and no joy. Not available. 1999 Defender TD5 110
24th Jul 2019 5:45pm |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 |
Is it the tap head or spindle, as screwfix have replacement inserts if its the spindle that has given up
24th Jul 2019 6:36pm |
Its the splines in the tap head that have worn 1999 Defender TD5 110
24th Jul 2019 7:23pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
24th Jul 2019 7:29pm |
Cheers. Had checked ebay a few times an none available. Now purchased. 1999 Defender TD5 110
24th Jul 2019 7:34pm |
For info they are ARES not ARIES, maybe this was effecting your search results > 110 XS Double Cab
25th Jul 2019 5:03am |
That might have been part of it 1999 Defender TD5 110
25th Jul 2019 8:45am |
Glad you got sorted though > 110 XS Double Cab
25th Jul 2019 8:51am |
Hopefully so. £49 for just the handle is better than having to spend on replacing taps and then having to squeeze under the bath and double bend myself! 1999 Defender TD5 110
25th Jul 2019 9:38am |
Turns a painful few hours into a five minute job touch wood! Plus you have spares for the future > 110 XS Double Cab
25th Jul 2019 10:19am |
