![]() | Home > Technical > Adding second battery - recommendations please |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2657 ![]() ![]() ![]() |
Hello Simon
I would say Gigglepin again. At least they will understand your requirements and have the knowledge of working on the vehilcles. Worth considering including power sockets to the rear and hard wiring in an invertor (i use mine to power my laptop when green laning). Good luck Mark |
Any auto electrician really. if you go to a so called "4x4 specialist" it s always more expensive.
I looked at all the different split charging systems and the best value and smartest piece of kit I found is from a firm called Adverc. It was 70 quid (at the time, a bit more now) for the equipment and 60 quid for a 110 AH numax deep cycle battery. I got a simple LED monitor for 12 quid and just cracked on with putting it in. the instructions in the adverc kit were fantastic. It's fit and forget, never had a problem with it, works beautifully. It also has a neat feature whereby if it senses that your starting battery is low on voltage, it flips over and uses the other battery to help it. have a look here http://www.adverc.co.uk/product/801 and also http://www.adverc.co.uk/batterymanagement/...id-system- |
This is actually the text I was after earlier
http://www.adverc.co.uk/batterymanagement/split-charging-systems |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
do it your self its not rocket science i bought a tray from devon 4x4 then 2 batterys
but when you get the batterys get a pair i know the oddasseys fit and optimas fit the tray so i went for oddasseys took me about an hour to do run them in parrallel or if your goign to run a fridge or such like get a split charge system it not hard work only thing is crimping cables if you need tio crimp them ? plus you need to make the vehicle eart longer it is so doable though regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
As steve said, really easy job, some intall pics in my library
