Home > Maintenance & Modifications > Remap - Dynachip v BAS
Page 3 of 3 <123
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I have the BAS 170 remote map, intercooler and all the silicone hoses (but the intercooler and hoses make no difference to the performance).
My mate 200 yards away has the similar Alive map, done at their Lincolnshire site.
Both are on 2014 110s.
The Alive map possibly has a fraction more mid-range, the BAS pulls a bit harder at higher revs.
However, I'd be happy with either of them.
Pete Bell at BAS I believe was the first person to be able to remap the 2.2 remotely, and it's a very well developed and constantly refined tune.
Neither remap is just a plug in boost box and Pete's plug in tool (which you use to download the tune to the vehicle) can do loads of other things apart from its primary purpose.
I'm not sure if that's really answered your question, but I hope it helps.
Post #840557 29th Jun 2020 8:55pm
A copy of the current map is sent including current parameters. You tell them any mods if any and it will be created ready to load yourself. My Alive tool allows me to view, delete DTC’s and change back if I wanted to. This is for a basic stage 1 map mind you. Above that you typically need physical upgrades anyway which is not so straight foreword such as updated intercooler etc. My concern with going higher would be the balance between longevity and performance. I’m quite happy with my stage 1. In what must be 6 years not one slightest gripe with it. 👍🏻 ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #840570 29th Jun 2020 9:44pm
jst
one thing to consider is if they come to your house or you take the vehicle to them its a one off remap and if you need to set it back to standard or someone else does (dealer) you have to pay for the map again.
Remote option you can set it back to std yourself.
I have had JE Engineering, TD5 inside on my td5s and L322s, both were great stage 1 ones and no problems over over 100k each.
remote BAS x2 stage 1 76k miles, mapped at less than 200 miles and going well on 110 and had another done
remote Alive - Stage 2 on my soft top.
All worked very well with different characteristics but then no two of my vehicles were exactly the same.
IRB is the other one i would seriously through into the pot. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #840632 30th Jun 2020 8:31am
Page 3 of 3 <123
