Home > Td5 > no electricity to injectors
fermin123
2000 Defender 130 Td5 HCPU Alpine White
hiii someone help my defender doesnt starts if i test the injectors with hawkeye tool everything is ok but when i hit the starter the injecytors are death
Post #73462 30th May 2011 3:11pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi, I would recommend that you get it computer diagnosed any dealer can do that. Or alternatively if someone in your area has a faultmate or something like that they can do it for you Smile
Hope this helps
Jack
Post #73470 30th May 2011 3:48pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Crank sensor? if its not working the injectors wont know when to work.
Steve
Post #73471 30th May 2011 3:50pm
fermin123
i have hawkeye tool. in here we dont have dealer.
crank sensor ins not the problem because when i hit the starter i see rpms in the live data and i only have one diagnstic code that is for the throttle but say if abs equippen my 130 is not abs i test my other ecu sensors from my other 110 td5 but now is 2.8 powerstroke
if i test the ibnjectors i hear the clicking noise but my compression is 150 psi
Post #73509 30th May 2011 7:22pm
