Home > Technical > Whats is this for |
Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 26th Jun 2019 2:49pm. Edited 2 times in total |
26th Jun 2019 2:03pm |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 |
I see the assembly diagram, (thanks) just not sure I get what the part is doing though ? I cannot see that moving it from one position to another does anything. still same question please, what does it do? Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
26th Jun 2019 2:29pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
It's the fresh/recirculate flap crank 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Jun 2019 2:32pm |
Yes of course, thanks Martin. Sweatysock
26th Jun 2019 2:37pm |
too slow Martin beet my to it Make shore the two parts of the flap crank are working. had one flap jam up mud and one of the plastic crank parts had broken |
26th Jun 2019 2:50pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
I had that cable fail on me years ago, but the dash control end instead.
The cable bent instead of sliding in the sleeve so replaced and all sorted. Go easy using those slider controls, mainly the control Martin mentioned or it can do this if you are too forceful or quick. Cheap job to fix, nuisance to do. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Jun 2019 4:11pm |
