Home > Puma (Tdci) > Bonnet gap
22900013A
Bonnet gap
How much of a gap should there be guys? On my USW the bonnet sits quite tight along the wings, but there is about 3/4 of an inch gap above the grille panel - enough to see the spring and latch mechanism. I thought the bonnet wasn't shut properly but that is as far as it will go. Its an aircon grille if that makes any difference - what kind of gap should there be?
Cheers. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #73200 28th May 2011 1:57pm
Zagato
Just measured mine which is a smidgen under 1/2" You maybe able to get it lower by adjusting the two stoppers on either side at the front!
Post #73201 28th May 2011 2:08pm
22900013A
It can't come any further down as then it would be compressing the wings.
Maybe it just shows up cos of the contrast with the silver bits and the green body, which wouldn't be so obvious on yours... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #73202 28th May 2011 2:10pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The gap on my 90XS is 1 cm under the R of Land Rover, with an even gap along wings.
Post #73205 28th May 2011 2:44pm
22900013A
Looks about the same as mine then. Maybe I am just expecting too much progress for the poor old Defender... Razz 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #73206 28th May 2011 2:50pm
110SEB
I'd measure mine but my tape measure doesn't go that far.
(for the bonnet gap that is)
I have a/c and same issue. Shut properly. Perhaps it's a design feature: additional air cooling.
Post #73224 28th May 2011 6:36pm
fekete
Thats normal they are built by brummies you know Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #73229 28th May 2011 7:00pm
They do say that there are only two man-made things that can be seen from space -- the great wall of China, and the panel gaps on a Defender.
Post #73237 28th May 2011 8:29pm
RED-DOT
And the Glasgow Celtic away strip?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #73289 29th May 2011 8:27am
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
It's great - with Defenders you never will find two the same Laughing Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #73316 29th May 2011 10:52am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
We will be living on Mars and still love and talk about them. Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Puma 110 SW
90 V8 SOFT TOP
Post #73323 29th May 2011 12:02pm
Funny you should say that.....
years back I shoehorned a 3.9 EFI into my old 90, which always ran hot, even with a big TD radiator (that's why I love diesels!)
anyway, for extra cooling i wound those front screws right down so the bonnet sat up slightly with a large gap at the front. It did help cooling a bit.
Post #73330 29th May 2011 2:09pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Quite interesting, I guess the gap is some kind of mud eater option?
Post #73342 29th May 2011 3:56pm
